New engine, idle surges.
Old Sep 9, 2003 | 11:41 AM
kb58's Avatar
Banned
Default New engine, idle surges.
I'm building up a car and just recently been idling the new engine. It idles between about 750-1000rpm, slowly moving up and down in speed, back and forth. Anyone know why? The engine's only lightly mod'd, header, CAI, and the EGR valve is removed and sealed off.
Is this something that's common for new engine installs, and will go away with time once the ECU "figures things out," or is it something more serious.
Old Sep 9, 2003 | 12:11 PM
CHK4TIX's Avatar
Default Re: New engine, idle surges. (kb58)
well, there is a big topic someplace on here about all the possibilities of the problem. Some say vacuum leak, some say fast idle or your eacv, but with mine it actually ended up being my ecu. Since i replaced it i dont have any surging problems. if i can find the link i will post it
Old Sep 10, 2003 | 03:32 PM
user 9782082308's Avatar
Default Re: New engine, idle surges. (CHK4TIX)
Its usually the idle control valve on the bottom of the tb. Take the cover off and you should see a white plastic thing with a brass looking bullit in the middle (bad description, I know). Tighten the white plastic piece til it bottoms out. That should take care of it. If you need pictures of it email me.
Old Sep 10, 2003 | 04:09 PM
PetroGuyX's Avatar
my vote gets a vacuum leak, my 92 S did the same thing and the problem was a vacuum line, but it didn't do it all the time
Old Sep 11, 2003 | 05:16 PM
kb58's Avatar
Banned
Default Re: (PetroGuyX)
Alright, thanks. I'll check out everything. It's getting close to being drivable so I'm getting a bit excited.
Pugh_4992
Jan 11, 2012 08:46 AM
xpdude
May 15, 2010 04:43 PM
nevamind
May 17, 2004 10:32 AM
inhonda
Mar 17, 2003 02:11 PM
hondafrk
Oct 1, 2002 04:03 AM
