oil light blinking, but has good oil pressure?
Old Sep 9, 2003 | 10:56 AM
fastludeh22's Avatar
Default oil light blinking, but has good oil pressure?
just as title says. ill have more info as soon as i can take a look at it.
i was driving, it started flashing so i pulled over. i put in some oil and it still kept blinking, but my oil pressure gage was reading normal, almost too high once i added oil.
Old Sep 9, 2003 | 11:06 AM
Sephro's Avatar
Default Re: oil light blinking, but has good oil pressure? (fastludeh22)
how is your oil level? Was it full after you added the oil?? Usually that means it's too low on oil.
Old Sep 9, 2003 | 11:10 AM
CHK4TIX's Avatar
mine did that about a month ago when i was racing. i was going about 90, when mine flashed. i have not idea why my pressure was fine as well. does anyone have any info.
Old Sep 9, 2003 | 11:19 AM
Greyout's Avatar
Default Re: oil light blinking, but has good oil pressure? (Sephro)
the signal wire on your stock oil pressure sensor might be coming loose, or the sensor itself is going bad.
I have an OEM sensor if you want it.
Old Sep 9, 2003 | 11:20 AM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote"> but my oil pressure gage was reading normal, almost too high once i added oil.</TD></TR></TABLE>
i don't like the way that sounds "almost to high" ?? if you have a blockage some where it can cause you oil light to come on if there is some foriegn matter blocking the oil sending unit, and that would acount for "almost to high" what does that mean?? now i know the seding unit trips the light if oil is to low, but maybe it will if oil press is to high, only a guess cannot confirm? (don't spread misinformaton)
you havew an aftermarket gauge, ? what does it read at idle and then after you out more oil in.
Old Sep 9, 2003 | 11:25 AM
Greyout's Avatar
Default Re: oil light blinking, but has good oil pressure? (prelittlelude)
also, do you have your aftermarket gauge tapped right by the OEM one, or somewhere else?
Old Sep 9, 2003 | 12:47 PM
Prelude Vtec 23's Avatar
Default Re: oil light blinking, but has good oil pressure? (Greyout)
Your oil pump is most likely failing, how many miles do you have on it? You might want to try replacing it.
Old Sep 9, 2003 | 12:55 PM
CHK4TIX's Avatar
Default Re: oil light blinking, but has good oil pressure? (Prelude Vtec 23)
well, i know on mine it wasnt the oil pump. i checked that out during my rebuild this month.
Old Sep 10, 2003 | 12:12 PM
Default Re: oil light blinking, but has good oil pressure? (CHK4TIX)
ok the oil pump only has 10 miles on it. i just replaced it.
the aftermarket oil pressure gage is tapped rght on the oil pump, where i tapped the feed line for the turbo. this kind of makes me worry about the blockage comment. maybe the oil pump is pumping, but there is blockege so the engine isn't seeing enough pressure. wouldn't that cause really high pressure.
one of the problems was when i poped my hood, the dipstick was gone.(dont ask) there was oil on the engine so i thought maybe some came out. i added some and the light still kept blinking. i was only a 1/4 mile away from the exhaust shop, so i dropped it off there to have the dp made.
do you think that it would blink from the oil temp? it was a hot day, and the turbo was dumping right out the side, blasting the block w/heat.
well see more when i go too get the car today.
MyUsernameName
Jun 15, 2017 02:06 PM
Retribution
Apr 1, 2009 06:22 PM
BigD306
Sep 26, 2008 06:59 PM
BACKintheDA
Jul 12, 2005 01:05 PM
livelife46290
Jul 14, 2004 05:15 AM
