what size precision turbo is a good size for my set up???
i currently have just a drag 3 kit with a turbonetics t3/t04e 54 trim i think. What would be a resonable upgrade. Im only running 7 psi tuned, would the sc60 be too big??? my freind says my motor would barely beable to spool it up, is this true any input would be appreciated thanks....
At 7 psi, why do you want a bigger turbo than you have now? Seems to me that your current would be ideal, you're not stressing it and not running out of charger.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hooked_up_gsr »</TD></TR><TR><TD CLASS="quote">i currently have just a drag 3 kit with a turbonetics t3/t04e 54 trim i think. What would be a resonable upgrade. Im only running 7 psi tuned, would the sc60 be too big??? my freind says my motor would barely beable to spool it up, is this true any input would be appreciated thanks....</TD></TR></TABLE>
well a sc60 is a 60-1 which I wouldnt run on anything less than probably 10lbs. Well you wouldnt really need to upgrade with your current setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hooked_up_gsr »</TD></TR><TR><TD CLASS="quote">wont the precision spool faster??? plus i will be running 10 once i go hondata</TD></TR></TABLE>
it depends on the trim you get
Bigger isnt always better
Im running sc34 57 trim, .63 a/r. .45 bar Im satisfied,
Contact arturbo he'll point you in the right direction
the.hamburglar
Mar 4, 2006 09:34 AM
Mr.DC2TurBo
Feb 15, 2004 07:24 AM
