boostin time! but got a few questions?
Old Sep 9, 2003 | 05:43 AM
95GS-R-N.O.S's Avatar
Default boostin time! but got a few questions?
b18c1
endyn 9:1
eagle rods
intank fp
b&m regulator
full race kit t3/t60-1
aem ems
basically have all the boltons msd,act 6pck,spoon flywheel
but my question is what size head gasket? and also what size injectors?
im trying to make 400+hp
Old Sep 9, 2003 | 05:47 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: boostin time! but got a few questions? (95GS-R-N.O.S)
use the stock headgasket and get some720cc injectors.
Keep it simple.
Old Sep 9, 2003 | 07:53 AM
Flamenco-T's Avatar
Default Re: boostin time! but got a few questions? (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">use the stock headgasket and get some720cc injectors.
Keep it simple.</TD></TR></TABLE>
headgasket size depends on the bore size.
As far as bore sizing, is your block sleeved ? if not, the most you can bore out is .020 over, which is about 81.5mm. If it is sleeved, then go about 82-83mm, you'll have a slightly larger bore, but gives you room for larger bores in the future is anything do happen.
If you use stock bore or .020 over, then use OEM, otherwise, go with Cometic gasket
stan
boostedblue23
Engine Machining & Assembly
Nov 2, 2018 09:50 AM
onlinehost
Dec 9, 2005 02:40 PM
Appleton21
Aug 31, 2005 10:02 AM
hondaapi
Oct 20, 2004 09:42 PM
VTC_CiViC
Mar 23, 2004 07:57 PM
