need a piston rod combo for a sleeved 2.0 gsr block 84mm
Old Sep 8, 2003 | 10:19 PM
junya16's Avatar
Default need a piston rod combo for a sleeved 2.0 gsr block 84mm
runnin jun 3 cams and i'm in arizona where i can only get 91 octane so i'm lookin for like a 11:3:1 compression pistons and prob just some eagle h beams but i can't find any luck w/ the pistons...know anyone who makes em around that comp????
Old Sep 9, 2003 | 05:57 AM
no2psi's Avatar
Default Re: need a piston rod combo for a sleeved 2.0 gsr block 84mm (junya16)
Junya,
What happend to the poor mans type r? Who is doing your sleaving? Anyways you can get them from http://www.raceeng.com/ Part number "WI-K567M84" Wiseco 84mm 11.3:1 compression. I think they are $430 or so. But if you buy the eagle rods with the pistons you get a discount. Good luck.
Old Sep 9, 2003 | 06:43 AM
eggiel's Avatar
Default Re: need a piston rod combo for a sleeved 2.0 gsr block 84mm (no2psi)
yeah call race eng. tell john eggie from puerto rico sent you he will hook you up good for piston go with cp for rod crower econo they rock good
Old Sep 9, 2003 | 07:24 AM
dfoxengr's Avatar
cunningham/arias if you can afford it
Old Sep 9, 2003 | 09:02 AM
vtecvoodoo's Avatar
Future Texas Boy
eagle/je
eagle/IB
Old Sep 9, 2003 | 10:06 AM
junya16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2psi &raquo;</TD></TR><TR><TD CLASS="quote">Junya,
What happend to the poor mans type r? Who is doing your sleaving? Anyways you can get them from http://www.raceeng.com/ Part number "WI-K567M84" Wiseco 84mm 11.3:1 compression. I think they are $430 or so. But if you buy the eagle rods with the pistons you get a discount. Good luck.</TD></TR></TABLE>
i got my hands on another block that already had the darton sleeves and its fresh from the machine shop....but thanks for the info those pistons sound like exactly what i want...and its with a b16 head..are those rated for a straight gsr or a type r??? just curious
Old Sep 9, 2003 | 02:32 PM
no2psi's Avatar
junya16,
Dude, I goofed up. Those pistons are for b20's with a b20 head. I called and talked to them. But that guy didnt seem to know what he was talking about. You might want to call them. I know for sure that you can get JE pistons from race engineering in either 10.5 and 12.5 compression with a b16 head. We used a set of those in our car.
Old Sep 9, 2003 | 05:12 PM
junya16's Avatar
Default Re: (no2psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2psi &raquo;</TD></TR><TR><TD CLASS="quote">junya16,
Dude, I goofed up. Those pistons are for b20's with a b20 head. I called and talked to them. But that guy didnt seem to know what he was talking about. You might want to call them. I know for sure that you can get JE pistons from race engineering in either 10.5 and 12.5 compression with a b16 head. We used a set of those in our car. </TD></TR></TABLE>
trying to go for the 11:1 11:3:1 11:5:1 root but thank you for checkin on that info for me....i'll keep you guys updated as to what i get
Old Sep 9, 2003 | 09:19 PM
hybridEj6's Avatar
Default Re: (junya16)
hey jun who did you get that block from?
Old Sep 9, 2003 | 10:35 PM
junya16's Avatar
Default Re: (hvacfunded)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hvacfunded &raquo;</TD></TR><TR><TD CLASS="quote">hey jun who did you get that block from?</TD></TR></TABLE>
a friend of mine got it sleeved awhile back and its been sitting for awhile and he knew my current situation and said to just take his block but when mine's taken out to sleeve it and give it to him so he still has one...so just a lot less down time for me
Old Sep 16, 2003 | 11:35 AM
junya16's Avatar
goin w/ the 11:1 cp's....
Old Sep 16, 2003 | 01:45 PM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junya16 &raquo;</TD></TR><TR><TD CLASS="quote">goin w/ the 11:1 cp's....</TD></TR></TABLE>
Cool. CP pitsons make power. I've seen it with my own eyes.
I called CP and told them that their pistons make power and they told me "We already know that." Guess the secret is out.
Old Sep 16, 2003 | 09:30 PM
AllmotorJunkie's Avatar
I only have 91 here in CA but am running 11.5:1 arias pistons. I a sure if you stay under 12:1 compression...you will be fine.
Old Sep 16, 2003 | 09:44 PM
junya16's Avatar
Default Re: (AllmotorJunkie)
ya i'm just gonna mill the head a bit and run like 11:3:1 when all is said and done...talk to you on friday rocket
Leo.
Nov 8, 2006 08:17 AM
solspeed
Aug 7, 2006 05:30 PM
ptsaurus
Mar 20, 2004 05:33 PM
ntegls
Feb 22, 2004 06:11 PM
J22si
11
Jan 25, 2004 01:01 PM
