(EG 95 H22 swap) What do u guys use to fill the hole cut for the cable and shifter box so exhaust sm
Old Sep 8, 2003 | 08:25 PM
SpoonFed's Avatar
Default (EG 95 H22 swap) What do u guys use to fill the hole cut for the cable and shifter box so exhaust sm
Well I am done with the swap and was wondering what material u guys used to fill the access hole for the cables and the shifter area so rain or ect. doesn;t enter or what would be the best material to use ? Currently I am running open header until I get an exhaust and its killing me smoke coming into the car... Thanks guys...
Also, it the car seems to be studdering (sp) in the low rpms range is this b/c of the fuel pump still have stk one in ? thanks
Old Sep 8, 2003 | 09:21 PM
vinnymack's Avatar
Dr. Pepper can
Old Sep 9, 2003 | 07:37 AM
intedgra's Avatar
Default Re: (vinnymack)
all i did was take an aluminum sheet metal and shoved it in there with a few bolts but hot air still gets thru. i am now considering buying some thermotec insulating mat and slapping it on.
Old Sep 9, 2003 | 02:05 PM
hondaZvic's Avatar
Default Re: (intedgra)
i just put the interior back over...... hmm... maybe i should cover it with some sheet metal or something... it doesnt smell that bad. either that or im just use to it.
Old Sep 9, 2003 | 03:25 PM
k_spek's Avatar
Default Re: (hondaZvic)
I used two layers of dynomat to cover up the hole and the bottom of the shift assemby. I got the heavy duty dynomat with the aluminum backing. It just sticks on and you don't have to use a heat gun to apply it. Keeps ALOT of heat out and reduces the exhaust noise .
Old Sep 9, 2003 | 03:26 PM
poison's Avatar
Default Re: (EG 95 H22 swap) What do u guys use to fill the hole cut for the cable and shifter box so exhaus
I have a metal template I have cut out using cardboard and will use some high heat glue to put it on.
Center console is also going in to cover it all up.
Old Sep 9, 2003 | 04:18 PM
cccya's Avatar
i didn't use anything. just the center console, never had any problems...
Old Sep 9, 2003 | 04:50 PM
~~~InNeEdFoRsPeEd~~~'s Avatar
* B A N N E D *
Default Re: (laugHin22CX)
pix's
Old Sep 10, 2003 | 11:19 AM
SpoonFed's Avatar
ttt
Old Sep 10, 2003 | 12:10 PM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinnymack &raquo;</TD></TR><TR><TD CLASS="quote">Dr. Pepper can </TD></TR></TABLE>
dam skippy
Old Sep 10, 2003 | 04:25 PM
cccya's Avatar
Default Re: (fastwanabe)
LOL thats GREAT!!!!!
Old Sep 10, 2003 | 06:40 PM
GSRswapandslow
Guest
Posts: n/a
i usually use one of the beer cans consumed from doing the swap to cover the hole
you get drunk and you get a cover...you can't beat that!
Old Sep 10, 2003 | 08:01 PM
CRneXt's Avatar
Hey man, A friend of mine did an auto to manual conversion swap in his EG Civic, and he made a cover out of sheet ABS. I know a guy that bought some like 1/2 inch thick in a 4x8 sheet for like $18.00 That would be good material I think. Use that, cut to the bolt pattern, and then caulk gun it in with GE SiliconeII from Lowe's or Home Depot.
All the Ideas sound great to me man.
JM2CW,
Scott AKA CRneXt
Old Sep 10, 2003 | 09:00 PM
DubbleD's Avatar
thas hella ghetto haha
Old Sep 11, 2003 | 09:06 PM
SpoonFed's Avatar
ttt
Chilloutdamn
Aug 28, 2012 04:11 PM
accord2civic2prelude
Apr 14, 2010 11:30 AM
grunt2001
Jan 29, 2009 12:50 PM
slowpoke81
Jan 11, 2006 07:26 PM
Maddox
Apr 17, 2005 08:32 AM
