my dyno at payn tech.
Old Sep 8, 2003 | 07:57 PM
platinum00's Avatar
Default my dyno at payn tech.
after a semi long drive to payn tech today , here is what i put down at 12psi, tunned on a hondata s200, 3 bar map.
170.9 hp
168.2 tq
now this is a mustang dyno, i read the normal conversion for a dynojet is +~15%
so thats
196.5 hp
193.4 tq.
this torque rules. tom did a hell of a job.
he told me flat out my exhaust sucks. haha, i running a dc sports 2.25 inch, i guess im looking at 30 + whp if i add a 3 inch exhaust. what do you guys think.
o yea this is a small sohc greddy turbo , i belive t04h.
platinum
Old Sep 8, 2003 | 08:28 PM
InTeGrA B18b1's Avatar
Default Re: my dyno at payn tech. (platinum00)
these small turbos put out some good tq!!!!
Old Sep 8, 2003 | 11:04 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
You sure do have a lot of torque for a D16. What have you done with it?
Ah, don't worry about Tom, he told me my exhuast sucks too.
I'm also running a 2.25 exhuast, it's a Apexi though.
He also told me that my custom turbo kit at 5psi was only going ot put down around 170-180 at the wheels on the Mustang Dyno. He was like "Ah.. I already know what it going pull anyway, it's going to pull around 170-180whp at 5psi". Then I put down 200whp at 5psi.
Then he said "Eh not bad, I'm impressed with the kit, turned out pretty well!".
Then about 5 mins later, Tom went back to saying how my exhuast sucked again.
Ah Tom, you gotta love the guy.
30whp would be NICE from just adding a 3 inch exhuast, but I doubt that I would actually see THAT much of a gain. But I'm only pshing 5psi, and you're pushing 12psi, so you should see a bigger gain than I would.
Do you have a high flow cat or a test pipe? That could really help out too!
Nice# btw!
Old Sep 9, 2003 | 03:14 AM
maddog20's Avatar
Default Re: my dyno at payn tech. (Snafu-Si)
Bascally same setup Tuned at Payn Tech 184 Hp 164tq. no cat HKS Hiper exhaust 8psi
Old Sep 9, 2003 | 03:20 AM
platinum00's Avatar
Default Re: my dyno at payn tech. (maddog20)
so maybe my exhaust is not so bad after all. here is the setup im running
8.5.1 compression, port pollished head. 3 angle valve job.
maddog20:
with you putting down that much at 8psi. makes me think something is wrong. any ideas guys.
Old Sep 9, 2003 | 03:55 AM
DaveF's Avatar
maybe his compression is higher than yours and that is part of the reason.
Old Sep 9, 2003 | 05:50 AM
platinum00's Avatar
Default Re: my dyno at payn tech. (2.2Lcivic)
good point. that is prolly what it is.
so you guys think it's worth it to upgrade a 3 inch exhaust, how much power you think i will get.
platinum
Old Sep 9, 2003 | 05:53 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
yeah with lower compression you can have more boost but you lose alot of Hp that people with higher commpression would see. Why did you bring the compression so low?
Old Sep 9, 2003 | 06:28 AM
I Like Boost's Avatar
Default Re: my dyno at payn tech. (HybridcivicLS-T)
only 12 psi? your built turn the boost up.
Old Sep 9, 2003 | 07:10 AM
Pengo's Avatar
damn u should def go to at least 2.5 or 3 if ur running 12 psi on that bad boy. i guarantee it will make a noticeable difference. good numbers for another sohc
Old Sep 9, 2003 | 07:16 AM
HXMan's Avatar
How long was your drive? Bet mine was longer.
Old Sep 9, 2003 | 08:00 AM
platinum00's Avatar
Default Re: my dyno at payn tech. (HXMan)
i made the compression so low because im stupid and did not do enough reseach on turbo engines. if i do it again it will not be so low.
why the low boost. tom explained to me anything over 12psi and it would be a time bomb waiting to go off. he said my sleeves "might" crack. i was thinking of turning it up to 15. what do you think. i do have a block gaurd. also since i was tunned at 12- 13 psi. you think it's safe to do 15 now. or will my a/f and timing be all off. i think its linear so i should be fine. any ideas.
how much gain with a bigger exhaust, any recomendations. should i stick with a high flow cat or just run "test" pipe
platinum.
Old Sep 9, 2003 | 08:02 AM
platinum00's Avatar
my drive was about 4.5 hrs. shoudl have been like 4, but i got stock in some traffic, and was ***** footin it.
on the way back i was rippin *** with my new setup. and got a ticket. hahahah. wtf
platinum.
Old Sep 9, 2003 | 09:46 AM
HXMan's Avatar
My drive was like 8 hours. Stock block and stock internals I had tuned to 10psi...never ran that much myself though.
I would think with rods and pistons you could have gone higher then 12psi....
You just have a D setup correct? Blocks are cheap for you.
Old Sep 9, 2003 | 09:52 AM
platinum00's Avatar
yes blocks are cheap, but my hands are still sore from building this one. hehe
you think i can turn it up as is. or do i need to retune it for 14-15.
how much will this little turbo push, 15psi.
Old Sep 9, 2003 | 10:18 AM
fusher's Avatar
Just unbolt the exhaust and see what happens. If it makes a difference we can just weld up a nice 3" exhaust. No reason to spend lots of cash on it.
Old Sep 9, 2003 | 10:33 AM
platinum00's Avatar
Default Re: my dyno at payn tech. (fusher)
i agree, but bigger exhaust wll lean me out a little and im already pushing it. im assuming i would need to retune. or at leat test on a wideband to check for a/f
ideas.
Old Sep 9, 2003 | 10:34 AM
platinum00's Avatar
Old Sep 9, 2003 | 10:37 AM
fusher's Avatar
What does your a/f curve look like? Lets see that dyno plot.
Old Sep 9, 2003 | 10:38 AM
platinum00's Avatar
i need to contact tom to get it. i think the cop took it when i got a ticket on the way home. i cant find it. i do have the hp/tq graph though.
Old Sep 9, 2003 | 11:00 AM
HXMan's Avatar
Cop took your Dyno plot? WTF. He had no reason at all to do that. ******.
Old Sep 9, 2003 | 11:06 AM
platinum00's Avatar
yea he was all giving me **** about my intercooler and having no front plate. i think it might have been a mistake. i was like dude i just took off my plate cause i had to cut my bumpter to fit this intercooler in there. he is like yea right. im like dude look, here is the graph from today, i just did it.
im assuming he just left it in his car.
Old Sep 9, 2003 | 01:41 PM
maddog20's Avatar
Comp is 9.6 to 1
Old Sep 9, 2003 | 02:03 PM
platinum00's Avatar
Default Re: (maddog20)
i wish i would have keep that compression or went higher.
Old Sep 10, 2003 | 05:04 AM
platinum00's Avatar
Default Re: (platinum00)
o yea, my spool up time was slow too, i did not hit full boost till like 4900 rpm and it starts at like 3900
any ideas. on that or do you think it's the exhaust again
platinum
