NEED TURBO CIVIC HELP
Old Sep 8, 2003 | 12:42 PM
gdrum's Avatar
Default NEED TURBO CIVIC HELP
Have 93 dx 1.5L d15 motor with junkyard kit. Runs fine, starts fine, no engine lights. Burns oil out exhaust hardcore smokey when idleing but not bad when spooling. What could be problem? Everythign appears hooked up right, compression is perfect. When first put it on it blew oil out the blow off valve, but that was because we found out oil pressuer was rediculously high and turned it down. Let me know what we should check for and look for. homemadeturbo didnt help at all...so i came here for knowledge. thanks
Old Sep 8, 2003 | 03:02 PM
gdrum's Avatar
Default Re: NEED TURBO CIVIC HELP (gdrum)
bump
Old Sep 8, 2003 | 04:52 PM
inspyral's Avatar
If it's an old turbo, the seals are probably gone, and it needs to be rebuilt. Pull off your inlet filter and see if there's any oil seeping out on the compressor side.
Old Sep 10, 2003 | 12:20 PM
BluePrintmfg.com's Avatar
Banned
Default Re: (inspyral)
I agree with inspyral, sound like you need to change that turbo or get it rebuilt, but take it out first and inspect the turbo.
Old Sep 10, 2003 | 02:02 PM
Sinner's Avatar
Default Re: (11sec.ALL MOTOR)
take off the turbo since you think you have to rebuild it anyway. Then run the car NA just to make sure its not your engine. Most junkyard turbos arnt worth rebuilding. Check for shaft play.
Nick
bads2k
Jan 21, 2009 07:24 AM
alex_s817
Mar 14, 2007 06:32 PM
dazcivic
Feb 26, 2007 03:23 PM
shiftgear8000
Dec 19, 2004 09:21 PM
2DXtreme
Jul 14, 2003 03:16 PM
