What wires do I jump on the passenger side window switch to get that window to work from the drivers
Old Sep 8, 2003 | 12:25 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default What wires do I jump on the passenger side window switch to get that window to work from the drivers
What wires do I jump on the passenger side window switch to get that window to work from the drivers side without a switch being on the passenger side. If I plug in the switch the window works fine and without it, does not work. I dont want a switch on the passenger side and I thought I could jump it, but haven't figured it out yet. Thanks again.
Old Sep 8, 2003 | 12:38 PM
sackdz's Avatar
Default Re: What wires do I jump on the passenger side window switch to get that window to work from the dri
Stick a multimeter or test light on the passenger window switch and see which 2 pins have continuity. If not I'll check later and let you know.
Old Sep 8, 2003 | 12:45 PM
Thank you. Please check and let me know, cause I dont have a meter.
Old Sep 8, 2003 | 12:47 PM
sackdz's Avatar
you could use a battery and 2 pieces of wire...
Old Sep 8, 2003 | 03:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">you could use a battery and 2 pieces of wire...</TD></TR></TABLE>
I'm lost how would that help me?
Old Sep 9, 2003 | 05:03 PM
Did you get a chance to find out what wires to jump?
Old Sep 9, 2003 | 08:01 PM
sackdz's Avatar
I forgot to check. If you take a battery and put a wire on each post, try different combinations of pins on the switch until it sparks, or put a lamp bulb in there... then jump the corresponding pins in the plug on the door.
Old Sep 9, 2003 | 08:09 PM
davidnyc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01PYTypeR#1140 &raquo;</TD></TR><TR><TD CLASS="quote">Did you get a chance to find out what wires to jump?</TD></TR></TABLE>
When you find out tell me the answer. You know that you and I are in the same boat.
Old Sep 10, 2003 | 06:53 PM
Will do.
Old Sep 15, 2003 | 04:45 PM
Can someone please help me with the answer to my door switch wire question.
Old Sep 16, 2003 | 06:42 AM
sackdz's Avatar
I'll try and remember to look today. But its not hard to figure out.
Old Sep 17, 2003 | 11:58 AM
sackdz's Avatar
OK its a 5 pin connector. THe two outside pairs need to be jumped, leaving the center one alone. So two jumpers, one for each side. I just stuck pieces of a paperclip in there.
Old Sep 19, 2003 | 09:01 PM
Thanks, you are the man!
Old Sep 24, 2003 | 03:09 PM
CrazyHondaBoy's Avatar
So it work that you roll down the driver window and passenser at the same time?
G Tiz
Honda Civic (2001 - 2005)
Nov 3, 2013 07:35 AM
Essenar83
Dec 14, 2007 06:35 AM
SOHC_MShue
10
Jul 30, 2006 12:50 PM
ChicagoMike
Mar 14, 2006 08:07 AM
spd18
Nov 9, 2003 01:57 PM
