How do you relocate your hood release cable to under the hood?
Old Sep 8, 2003 | 12:18 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default How do you relocate your hood release cable to under the hood?
How do you relocate your hood release cable to under the hood? Can you give me a link on how to do it step by step? Or maybe post step by step on how to do it? Couldn't find it in search. Thanks for your help.
Old Sep 8, 2003 | 12:23 PM
Bbasso's Avatar
Default Re: How do you relocate your hood release cable to under the hood? (01PYTypeR#1140)
Maybe its better if this was decussed in the IM way?
Old Sep 8, 2003 | 12:24 PM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01PYTypeR#1140 &raquo;</TD></TR><TR><TD CLASS="quote">How do you relocate your hood release cable to under the hood? Can you give me a link on how to do it step by step? Or maybe post step by step on how to do it? Couldn't find it in search. Thanks for your help. </TD></TR></TABLE>
How about we not discuss anti-theft type stuff on here.
Old Sep 8, 2003 | 12:30 PM
Default Re: How do you relocate your hood release cable to under the hood? (Chris N)
In this case explaining how to do it won't help the thief, because it's going to be under the hood anyway, At least I think it wouldn't hurt. If not can someone IM me a link or Step by Step instructions on how to do it.
Old Sep 8, 2003 | 12:46 PM
AssPenny's Avatar
Its easy.
1) Remove the cable completely.
2) Run the cable threw one of the rubber grommets in the firewall that leads to the engine bay.
3) Route cable along the edge of the hood/fender where the whiper water hoses run.
4) Run the cable over the driver side head light and under the radiator suppport .
5) Hook the cable up normaly to the latch.
This still does not stop some one from going threw the bumper cap or even through the front grill for that mater.
Old Sep 8, 2003 | 01:27 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: How do you relocate your hood release cable to under the hood? (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">
This still does not stop some one from going threw the bumper cap or even through the front grill for that mater.</TD></TR></TABLE>
Yup. Why would you re-route it when thieves simply go through the front grille 99% of the time anyways?
Old Sep 8, 2003 | 01:31 PM
AssPenny's Avatar
Default Re: How do you relocate your hood release cable to under the hood? (CivicCLMT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Why would you re-route it when thieves simply go through the front grille 99% of the time anyways?</TD></TR></TABLE>
Because stoping the 1% is worth the 5 minutes it takes to do this.
You can always build a metal channel to run the cable through so even if they do reach under the bumper or cut a hole, they won't be able to reach the cable. I did this on my old GSR, but have not had the time to make another one for my R.
Old Sep 8, 2003 | 03:46 PM
nightrider's Avatar
i will be doing this soon when i have the time. there is a good write-up on team-integra.net. i believe you must be a member though.
http://www.team-integra.net/se...able\
Redemption
Aug 14, 2008 04:23 PM
madmanmulligan
May 21, 2006 09:32 AM
cannan
Dec 28, 2003 09:40 AM
