Type R with removed Airbag SRS system and/or after market steering wheel question?
Old Sep 8, 2003 | 12:14 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default Type R with removed Airbag SRS system and/or after market steering wheel question?
Type R with removed Airbag SRS system and/or after market steering wheel question? How do you get the SRS light off after taking out airbags and SRS controler? Thanks for your help.
Old Sep 8, 2003 | 12:46 PM
98ITR #72's Avatar
Default Re: Type R with removed Airbag SRS system and/or after market steering wheel question? (01PYTypeR#11
I just pulled the instrument cluster out and pulled the buld out.
Problem fixed.
Old Sep 8, 2003 | 12:50 PM
AssPenny's Avatar
A piece of black tape fixes that problem too
Old Sep 8, 2003 | 12:57 PM
CW-ITR's Avatar
Crawl underneath the dash and pull out the connector that hooks up to the buld.
Old Sep 8, 2003 | 12:59 PM
skunked's Avatar
After I unplugged the SRS control module my light went off.
Modified by skunked at 5:06 AM 9/9/2003
Old Sep 8, 2003 | 01:56 PM
IGGY's Avatar
You can put a 2 ohm resistor and have the light go out, while still retaining the use of the other SRS bag.
Old Sep 8, 2003 | 02:26 PM
Im_In_There's Avatar
i just pulled out the bulb. works like a charm.
Old Sep 8, 2003 | 02:30 PM
Tommy_Gunns's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGGY &raquo;</TD></TR><TR><TD CLASS="quote">You can put a 2 ohm resistor and have the light go out, while still retaining the use of the other SRS bag.</TD></TR></TABLE>
What other SRS bag
Old Sep 8, 2003 | 03:37 PM
EleanoR's Avatar
Unplug the yellow connector on top of the cluster. That will solve the problem
Old Sep 8, 2003 | 04:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EleanoR &raquo;</TD></TR><TR><TD CLASS="quote">Unplug the yellow connector on top of the cluster. That will solve the problem </TD></TR></TABLE>
I like this one best! I think I'll do just this. Thank you for everyone's replies.
Old Sep 8, 2003 | 04:27 PM
slackeR1366's Avatar
I did that but my ABS stopped working also?
Old Sep 8, 2003 | 06:00 PM
non-VTEC's Avatar
this will work very well........i did the exact same........one simple harness in the back of the cluster fixes everything......
Old Sep 8, 2003 | 06:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R1366 &raquo;</TD></TR><TR><TD CLASS="quote">
I did that but my ABS stopped working also? </TD></TR></TABLE>
Are you saying that you lost your ABS from unpluging the yellow plug on the back of the instrument cluster?
Old Sep 8, 2003 | 07:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01PYTypeR#1140 &raquo;</TD></TR><TR><TD CLASS="quote">
Are you saying that you lost your ABS from unpluging the yellow plug on the back of the instrument cluster?</TD></TR></TABLE>
yeah that's what happened to mine. I unplugged it, then a couple of days later, I noticed that not only did my SRS light go off but the ABS light stopped coming on.
I'm not sure if it's disabled b/c I haven't had the need for it to go on, but I did a quick brake test and my wheels ended locking up...no ABS
Old Sep 8, 2003 | 07:38 PM
Take the SRS bulb out if you still want the ABS light.
It is not that much harder to remove the bulb then to just disconnect the yellow harness.
Old Sep 8, 2003 | 07:52 PM
I should try to remove the yellow plug to see if the ABS stops working, and if it does I could put a switch on it so that I can turn the ABS on and off. I might be to lazy to do this, but someone should try it. Free cool functional Mod!
Old Sep 8, 2003 | 07:54 PM
thk's Avatar
thk
Members Only
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01PYTypeR#1140 &raquo;</TD></TR><TR><TD CLASS="quote">I should try to remove the yellow plug to see if the ABS stops working, and if it does I could put a switch on it so that I can turn the ABS on and off. I might be to lazy to do this, but someone should try it. Free cool functional Mod!</TD></TR></TABLE>
It should just disable the ABS indicator light. Not ABS itself. But Edwin states otherwise. Kind of odd if you ask me since it's just an indicator light and shouldn't be tied in with anything. Interesting. Good thing I love the ITR ABS and left the plug in.
I didn't feel like dealing with taking a part the cluster or having the ABS warning indicator out so I just deal with the SRS light. You ignore it after awhile.
Modified by thk at 12:07 AM 9/9/2003
Old Sep 8, 2003 | 07:57 PM
thk's Avatar
thk
Members Only
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tommy_Gunns &raquo;</TD></TR><TR><TD CLASS="quote">Take the SRS bulb out if you still want the ABS light.
It is not that much harder to remove the bulb then to just disconnect the yellow harness.</TD></TR></TABLE>
My cluster doesn't have a bulb for the SRS light. It seems to be a LED.
Edit - Nevermind. Tommy_Guns said it's a bulb after all. Thanks again Tommy.
Old Sep 8, 2003 | 08:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">It should just disable the ABS indicator light. Not ABS itself.
Modified by thk at 12:07 AM 9/9/2003</TD></TR></TABLE>
that's what I thought. i'm gonna check it out in the morning b/c I been dying to get that SRS light off
at first you do ignore it most of the time and black tape doesn't hurt either...but it's really annoying now
humboldt_skim
14
May 27, 2008 10:39 PM
lamboextreme
10
Sep 24, 2007 06:09 PM
92ehatch
Jul 30, 2006 05:57 PM
!xobile
Jan 24, 2006 09:01 AM
