blue box/walbro intank @ 8 psi VS. SMC/450s @ 8 psi
Old Sep 8, 2003 | 11:26 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default blue box/walbro intank @ 8 psi VS. SMC/450s @ 8 psi
What's more reliable? Provides more power? Post opinions of both please.
Old Sep 8, 2003 | 01:23 PM
Default Re: blue box/walbro intank @ 8 psi VS. SMC/450s @ 8 psi (fnananon)
bump
Old Sep 8, 2003 | 03:29 PM
Disco Stu's Avatar
Well, I think technically the blue box is 'written' for 5.5 psi. Granted, I know a guy around here who is running a blue box with an intank 255 pump and he's running 8-10 lbs and he says he isn't having problems with it. Personally, I always think of the blue box as a cheap solution (although I know it works great for a lot of people) so I say go with the 450s and the smc. It gives you more headroom and the ability to tweak and tune a little bit.
What kind of car/ecu are you running this on? Have you ever thought of chipping using ghettodyne (if you're obd0) or uberdata (if you're obd1) I'm running a PM6 ecu, so I'm able to chip, which I like better than both the blue box and the smc/450s.
Good times!
Old Sep 8, 2003 | 07:09 PM
Cee_mon's Avatar
Default Re: blue box/walbro intank @ 8 psi VS. SMC/450s @ 8 psi (Disco Stu)
i would have to say the 450 and SMC....the blue box runs to much fuel and losses power because of that.
Old Sep 8, 2003 | 08:02 PM
SOFLSOL's Avatar
Go with SMC500 and 450's. Tunability.
Old Sep 8, 2003 | 08:17 PM
keebler65's Avatar
Default Re: (SOFLSOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOFLSOL &raquo;</TD></TR><TR><TD CLASS="quote">Go with SMC500 and 450's. Tunability.</TD></TR></TABLE>
and a wideband of course you'd never be able to get the blue box perfect - every setup is different.
salman
Mar 1, 2006 11:26 AM
Bimmerman
May 6, 2005 04:30 PM
eNRGyNiX
Apr 17, 2005 09:39 AM
lDanny
Mar 30, 2005 02:14 PM
93TurboSi
Sep 30, 2003 08:46 PM
