Valve Cover bolt won't tighten
Old Aug 19, 2001 | 07:56 PM
Halo's Avatar
Default Valve Cover bolt won't tighten
When I went to go putt my valve cover on after painting it, all of the bolts tightened except for one...........whick turns and turns but never gets tighter! Please help
[Modified by Halo, 8:57 PM 8/19/2001]
Old Aug 19, 2001 | 08:43 PM
Halo's Avatar
Default Re: Valve Cover bolt won't tighten (Teken)
if the inner thead bolt is stripped..........how difficult is it to replace?
Old Aug 19, 2001 | 09:23 PM
Turbo00's Avatar
New User
becareful with valve cover bolts remeber its only a 10mm
Old Aug 19, 2001 | 09:41 PM
OneThirtyEight's Avatar
Default Re: Valve Cover bolt won't tighten (Turbo00)
ah those top crown bolts are a BITCH to get off if they are stripped, this is most likely the problem, I stripped mine once overtightning those bolts, you have to be REAL careful tightening them, I had to cut mine off carefully with a dremel tool. Good luck.
heres what I suggest doing. Try to take it off, it IS stripped, if you can get it off replace it ASAP.
[Modified by 97blackteg, 1:41 AM 8/20/2001]
Old Aug 19, 2001 | 09:53 PM
Halo's Avatar
Default Re: Valve Cover bolt won't tighten (97blackteg)
I don't have a torque wrench, what is a safe-level to tighten these bolts? I ave a feeling I over tighened them
Old Aug 20, 2001 | 07:06 AM
keithv's Avatar
I just use a 10mm socket on a 1/4" drive. With this you can tighten the bolts as much as possible and they shouldn't be overtightened.
Hondalover15
Oct 8, 2012 04:12 PM
gsrswap
18
May 7, 2007 11:06 AM
AccordStuntin
Jul 16, 2006 05:45 PM
crxaddikt
Sep 19, 2002 10:08 PM
