Possible valve tick?
Quck senario: After the August track day at VIR I've noticed a ticking sound coming from the engine bay, specifically from the exhaust side of the engine. My fear is that a valve is ticking but it's more audible when the engine is cold but lessens noticably after the engine warms up. During the track event the car ran normally and was not overreved at all. Also, idle seems to be normal. This sound seems to be more than just noisy injectors, but could one be louder than the others?
thanks for the input
J
J
I thought that too. Last valve adjustment was less than 10,000 miles ago. I usually adjust them every 15,000 and I run the car pretty hard on and off the track. Perhaps a valve adjustment would help. I've never heard a car with bent valves. I assume it's pretty noticeable?
It sounds like a valve adjustment deal to me too. You said you drive the car pretty hard, and aren't adjustments scheduled for every 15,000 miles? So, 5,000 off, with harddriving..
You say it happens when cold? Do you have aftermarket pistons? Maybe it's piston slap your hearing. But I agree with these guys especially since you say you track the car and run it hard off the track. I would do the valve adjustments a little sooner. Maybe 10-12k miles.
99gsrfasho
Dec 31, 2009 10:07 PM
