Will an OBD2 D-series motor work with an OBD1 ECU?
Old Sep 8, 2003 | 08:39 AM
inline4's Avatar
Default Will an OBD2 D-series motor work with an OBD1 ECU?
I searched. No luck. I'm getting a 96+ D-series non-vtec motor from a friend, and was just wondering if I could use a p06 with it. I have a 92 Civic Hatch.
Old Sep 8, 2003 | 09:23 AM
BauleyCivic's Avatar
Risky Business
Default Re: Will an OBD2 D-series motor work with an OBD1 ECU? (inline4)
you need to change the distributor, and u might need to change a few plugs to accomodate the OBDI ECU
Old Sep 8, 2003 | 09:25 AM
aw1234dude's Avatar
Default Re: Will an OBD2 D-series motor work with an OBD1 ECU? (BauleyCivic)
If he is giving you the OBD2 harness along with the motor then you can just get a OBD2 to OBD1 conversion harness to use the OBD1 ECU.
Old Sep 8, 2003 | 09:44 AM
SOHC_MShue's Avatar
Default Re: Will an OBD2 D-series motor work with an OBD1 ECU? (aw1234dude)
yea if you already got the ecu then you just need to get a conversion harness.
Old Sep 8, 2003 | 10:41 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Very easy remedy.
Keep the OBD2 distributor.
Run your OBD1 engine harness, and use your OBD1 injectors.
To keep the OBD2 distributor, all you'll have to do is repin the two fat wires from the OBD2 dist. plug into the "extra" plug that your OBD1 engine harness will have.
The colors will even match up. One will be like a black wire with yellow tracer, the other should be blue.
I'll be back with pics on how to do this...
As far as the ECu goes, the OBD1 will work just fine.
Old Sep 8, 2003 | 10:44 AM
B18C5-EH2's Avatar
Former Moderator
Loved
As promised:
Very simple.
Why do this instead of swapping the distributor?
1. Newer distributor is less likely to fail
2. Don't have to reset the timing
Old Sep 8, 2003 | 11:40 AM
inline4's Avatar
Default Re: Will an OBD2 D-series motor work with an OBD1 ECU? (B18C5-EH2)
Thank you! I Honda-tech
Old Sep 8, 2003 | 11:53 AM
TwistedHatch's Avatar
depends on the year of the car, if you run the whole obd-2 motor harness injectors and distributor it will plug right into an obd-1 car and the obd-1 ecu will work, now if your running it in a obd-2 car then the obd-1 ecu won't work without a jumper......
Old Sep 8, 2003 | 12:02 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Will an OBD2 D-series motor work with an OBD1 ECU? (TwistedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwistedHatch &raquo;</TD></TR><TR><TD CLASS="quote">depends on the year of the car, if you run the whole obd-2 motor harness injectors and distributor it will plug right into an obd-1 car and the obd-1 ecu will work, now if your running it in a obd-2 car then the obd-1 ecu won't work without a jumper......</TD></TR></TABLE>
No it will not.
You're thinking of the Integra harness. I run an Integra OBD2 engine harness in my 1992 Civic, but the 1996-2000 Civic harness is nothing like the 1994-2001 Integra or 1992-1995 Civic harnesses.
The 1996-2000 Civic DX harness is all one piece and goes through the firewall.
Please be sure about things when you post about them, because there has been quite a bit of misinfo in this topic thus far guys.
Old Sep 8, 2003 | 05:19 PM
inline4's Avatar
so i have to get the whole obd1 fuel rail + injectors or just the injectors?
Old Sep 8, 2003 | 05:23 PM
JDM_ek9's Avatar
read B18C5 - EH's stuff I come on here to read his posts lol he has very GOOD INFO
Old Sep 8, 2003 | 05:25 PM
ghettochild's Avatar
just listen to b18cs5 YO!
Old Sep 8, 2003 | 05:54 PM
EARLdaSQUIRREL's Avatar
official honda whore
use the harness that came with your car (obd1 harness... then repin the dist plug so you can use the obd2 dist.. its as easy as that
Old Sep 9, 2003 | 06:11 AM
inline4's Avatar
Default Re: (coptzer)
what about the engine harness. do i need an obd1 engine harness?
Old Sep 9, 2003 | 06:25 AM
BigMig's Avatar
Default Re: (inline4)
c'mon man are you not reading peoples feedback?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Run your OBD1 engine harness, and use your OBD1 injectors.</TD></TR></TABLE>
Old Sep 9, 2003 | 03:03 PM
inline4's Avatar
Default Re: (BigMig)
yeah, i'm just making sure.
Hmm.. no one said anything about the alternator, but some of my friends say i need an obd1 alternator.. true or false?
diviznrider
13
Apr 19, 2019 01:38 PM
novaslean
Apr 14, 2010 09:23 AM
NOman0608
Jul 26, 2007 10:28 AM
97DGreenEx
Oct 13, 2006 06:21 PM
hatchy
Mar 31, 2002 08:24 AM
