whats a good spray on lubricant/oil?
My buddys throwout bearing is making a crapload of noise, so we need something to lube it up with.
I was told wd40 really isnt good for this kind of thing, as its more of a degreaser/cleanser than a lubricant.
So what would be good to get?
it would be nice to have something that works good on other things also(might need to lube up my shifter too).
do they have like.. motor oil in spray form? I'd guess that that stuff would work good?
any input ?
TIA
any input ?
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">My buddys throwout bearing is making a crapload of noise, so we need something to lube it up with.
any input ?
TIA</TD></TR></TABLE>
Umm...if your throwout bearing is making a noise then you need to get a new one. Don't be cheap and try to lube it up. When I ripped my transmission apart, I found that only one of my bearings was making a faint clicking noise when you spun it, and this was causing my entire motor to make rumbling and clanking noises...if a bearing is not 100% silent, then you need to replace it. PERIOD
Also...there is this stuff that you can buy at pep/boys autozone called anti-seize lubricant or assembly lube...use that
any input ?
alright, i'll get that assembly lube.
and yeah, i'm not even 100% sure its the throwout bearing thats messed.. its just that his car makes a pinging sound when he engages his clutch, I was told before that this was probably the throwout bearing.
also its coming right from that throwout bearing area.
it makes a noise when the clutch is depressed? or it makes a noise and then goes away when the clutch is depressed, is it a squeaking noise or a clanking noise...
if the noise is a chatter/clicking/clanking and it goes away when the clutch is depressed, he needs a new input shaft bearing
My Writeup on how to replace the input shaft bearing: https://honda-tech.com/zerothread?id=596873
Have a ball
Have a ball
aahhh its prolly the input shaft bearing then, haha.
oh well... i'll try to lube the ****, if not.. prolly just leave it till its ded, dont really want to tear apart a tranny just to fix a creak.
thanks a bunch tho
thanks a bunch tho
vtek9
Feb 21, 2008 06:27 PM
tha Big EZ
Jul 17, 2003 08:40 PM
