What ECU burn to run
Old Sep 7, 2003 | 01:37 PM
loudog18's Avatar
Default What ECU burn to run
Running an ls sleeved too a 2.0l with 12.5 cr . b16 head with gsr tranny. planned on running ef-1 cams m22 or m23.
I have a p28 and wondering what kinda of burn would be best for this setup?
Old Sep 7, 2003 | 07:04 PM
96redgsr's Avatar
id say hondata...ive got an "almost fully built" gsr, running skunk2 ECU, and its waaay too rich, i need a vafc, but i decided to just go with hondata next summer. i hear the s100 is all u really need, so ive uve already got the ECU, u can get it chipped for under 300, same price as the skunk2 program about.
Old Sep 7, 2003 | 08:24 PM
Fobtions's Avatar
Default Re: (96redgsr)
yah most of the aftermarket tuner chips wont be too good for your setup. hondata !
Old Sep 8, 2003 | 09:46 AM
ALLMTRWHORE's Avatar
Default Re: What ECU burn to run (loudog18)
try the mugen program!
on of my 2 liters! we retarded the timing like around 10 and the mugen program pushes timing forward! just run higher psi of fuel and retard it and you should be fine! it's not a cure and should not replace hondata! we put hondata on it and it get 25 mpg and makes 220 whp instaed of 8mpg and we never dynoed it but it ran a 13.9 at palmdale on street tires to give a idea! keep posting to see how it works out for you
Old Sep 8, 2003 | 03:55 PM
Eyewitness's Avatar
Default Re: What ECU burn to run (ALLMTRWHORE)
Ehhh...Yeah the mugen prog alone sux ***** IMO for any daily driver...kiss your mpg goodbye....Hondata all the way
smoked08
Jan 10, 2011 02:50 PM
db8gsr_teg
10
Apr 18, 2006 04:43 PM
10K2HVN
Nov 20, 2002 07:16 PM
fukaintmuven
Nov 7, 2002 12:02 AM
fukaintmuven
Oct 26, 2002 07:33 PM
