Urgent Question: About rear disc brake conversion!
Old Aug 19, 2001 | 11:54 AM
HXMan's Avatar
Default Urgent Question: About rear disc brake conversion!
I got all the parts, and I am in the mood to do this. I have a complete 99 Si rear end, 99 Si prop valve, and 99 Si master cylinder.
I have the different proportioning valve......must I use it? Why? Does the pressure going to the front and rear brakes change so much when doing a rear disc conversion.
I want to know cuz removing the valve is probably going to be a beeaaach.
Old Aug 19, 2001 | 12:19 PM
G's Avatar
G
Default Re: Urgent Question: About rear disc brake conversion! (HXMan)
You should use it. Before you start, you should buy the right tool to remove those darn brake line nuts. Stripping just one would ruin your week. There is a difference in pressures between a disc brake system and a drum brake. To be safe, you should just replace it. You don't want to slam on the brakes and have the rear come around, would you.....(actually, that may be fun).....
By the way, do you have your stock o2 sensor, the one with 5 or 6 wires?
[Modified by G, 9:20 PM 8/19/2001]
Old Aug 19, 2001 | 07:21 PM
HXMan's Avatar
Default Re: Urgent Question: About rear disc brake conversion! (G)
Ok. It doesn't look all that hard afterall. I took a look at it today, and the prop valve isn't too far down the firewall.
I did get the whole rear suspension off, and started bolting up the Si rear suspension when I noticed the lower arm was bent! So I decided to use my original arm...while taking the hub assembly off the lower arm the connecting bolt busted! *****. Now I probably won't finish till tuesday when I have another day off.
Oh yea, I sold the 5 wire wideband O2 sensor a while back......I am curious, why did you want it?
Old Aug 20, 2001 | 09:10 AM
G's Avatar
G
I wanted to see if I can make a wideband o2 meter with temp correction. That would have been the perfect o2 sensor.........
Old Aug 21, 2001 | 01:58 PM
fastbrakes's Avatar
You don't need to swap the prop valve. The 99 Si and the 97 HB use the same valve, so you shouldn't need to change it on your coupe.
asianman139608
Oct 26, 2009 07:21 AM
Civic98KH
Mar 4, 2007 05:52 PM
EGhatched
10
Mar 31, 2004 08:45 AM
Egone
13
Aug 1, 2003 11:17 AM
HXMan
Aug 19, 2001 07:24 PM
