NITROUS installation.
Old Sep 7, 2003 | 07:14 AM
ross1459's Avatar
Default NITROUS installation.
i recently got a great deal on a nos kit from a friend of mine. only thing is i am not quite familiar with the installation of the kit.
anybody know where i can find i set of instructions for installing a NOS dry kit?
i'm 100% sure about everything except where the T-fitting for the vaccuum line plugs in. which line does it splice into??
Old Sep 7, 2003 | 09:07 AM
TREVER's Avatar
Default Re: NITROUS installation. (ross1459)
so cal speed shop in pomona cal has a tech help line. they are a major dealer for nos and should be able to get you some instructions
Old Sep 7, 2003 | 11:47 AM
T4eg's Avatar
Default Re: NITROUS installation. (TREVER)
just wire the solenoid up to the switch and mount the bottle and solenoid and run the lines.
Old Sep 7, 2003 | 02:22 PM
ross1459's Avatar
no dude, dry nitrous kits have another pressure line that pressurizes a vaccuum line either on the FMU or the fuel return line in order to raise the fuel pressure and keep everything from going lean. and i dont know where it installs. so if anyone has a NOS dry kit set up and knows where to tap the T, that'd be great.
Old Sep 7, 2003 | 06:05 PM
hndarcrb18c1's Avatar
Default Re: (ross1459)
The "T" taps into the vacum line for the Fuel pressure REG but MAKE SURE you have the Metal "T" with the Bypass Jet in it the Bypass jet points toward the Nos unit...
Old Sep 10, 2003 | 05:54 PM
ross1459's Avatar
Default Re: (hndarcrb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hndarcrb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">The "T" taps into the vacum line for the Fuel pressure REG but MAKE SURE you have the Metal "T" with the Bypass Jet in it the Bypass jet points toward the Nos unit...</TD></TR></TABLE>
thanks a bunch man, that's where i figured it went. i have the brass NOS T fitting. what's so special about it?
Old Sep 10, 2003 | 06:02 PM
quik1's Avatar
You should be able to unscrew one end of the T and there should be a jet inside.
Old Sep 10, 2003 | 06:05 PM
Turbogixxer's Avatar
Default Re: (quik1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">You should be able to unscrew one end of the T and there should be a jet inside.</TD></TR></TABLE>
It matters what kit he has. I have seen it both ways. Some have the jet in the nipple in between the solenoids and some have the jet in the "T" fitting for the Fuel pressure reg.
Old Sep 12, 2003 | 02:15 AM
ross1459's Avatar
gahhh.... i don't know whether it goes in the vac line or the fuel return line.
the T is brass, probably with a jet. it unscrews just like the nozzle. i'll check tomorrow. on the solenoid end, it has a blue regulator type thing with a barb fitting for the line.
does anyone have the instructions or know where i could find the instructions online??? either that or a picture of a dry nitrous setup? that would be all i would really need...
Old Jan 3, 2004 | 10:47 PM
South Bay Surfer's Avatar
From: South Bay, Torrance/Carson, CA, United States
could someone answer the above question regarding the T line because I have the same question/problem.
Old Jan 4, 2004 | 06:13 PM
bump
Old Jan 4, 2004 | 07:01 PM
Default Re: (iluvjasmine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvjasmine &raquo;</TD></TR><TR><TD CLASS="quote">could someone answer the above question regarding the T line because I have the same question/problem.</TD></TR></TABLE>
Like I answered the question before, I have seen the jet in the 't' and in the vacuum canister between the solenoids. Both were the same kit (5.0 mustang). The one with the jet in the canister was the newer kit. Maybe I am reading your question wrong? whats confusing you?
Ahknodd
Jun 23, 2009 12:08 PM
KURUPTinc
Feb 26, 2006 05:46 PM
NirVTEC
Sep 16, 2003 08:43 AM
krazykid
Apr 21, 2003 09:30 AM
