dry or wet kit
Old Apr 21, 2003 | 08:28 AM
krazykid's Avatar
Default dry or wet kit
is this a dry or wet nitrous kit when there is a line connecting the two solenoids that leads to a tube that u connect to ur fuel line which will be used to bring fuel to the solenoids adding with the n2o before they both reach the single nozzle that is mounted to the intake
Modified by B20Demon at 5:46 PM 4/21/2003
Old Apr 21, 2003 | 08:33 AM
Poop111444's Avatar
Default Re: dry or wet kit (B20Demon)
man i have no idea what you just said. But:
A dry nitrous kit will have one line (of nitrous) running into the intake
a wet kit will have two lines connecting to a single nozzle (one for nitrous, the other for fuel) so they are Mixed together before being injected into the engine.
Old Apr 21, 2003 | 08:48 AM
krazykid's Avatar
Default Re: dry or wet kit (si_mekanik)
there is a line that u connect on the fuel line to bring fuel between the two solenoids i have that will make the nitrous and the fuel mix allowing both to go through a line to the single inlet nozzle. it looks like the fuel and nitrous mix at the solenoids or something like that i will post a pic soon
Old Apr 21, 2003 | 09:02 AM
PM-Performance's Avatar
its a dry kit if its what im thinking of , its a blue diaphram thing that is actuated by vacumm when the nitrous is engaged it rises the fuel pressure.
Old Apr 21, 2003 | 09:16 AM
romeo619romeo's Avatar
Default Re: dry or wet kit (itr206)
look at the fogger.. 2 inputs = wet set up
Old Apr 21, 2003 | 09:30 AM
BoostedsiR's Avatar
that is right what b20 demon said thoose 2 silenoinds things one of them would definetly be for the fuel presure and you should have vacum line from your intake for juice. Did you by this **** from somebody used?
slowman
Oct 24, 2007 09:25 PM
slowman
Oct 24, 2007 09:24 PM
b16a4
Jan 18, 2007 01:54 PM
ajshades
Feb 3, 2003 07:16 PM
