Help me choose my slicks !
The car: 97 Integra GSR turbo, will have mid/ high 4xx whp at the track.
Cutoff at 8500 rpm, here are the tranny ratios.
The goal : mid 11 seconds, as close as possible to 130 mph.
1. 3.230
2. 1.900
3. 1.269
4. 0.966
5. 0.714
FD: 4.266 ... LS tranny, I know
The slicks must be 15 " to clear the ITR brakes.
I was thinking of getting 15x8 Diamond or Bart wheels with 24 x 9.2 x 15 M&H slicks.
What do you think ?
1. 3.230
2. 1.900
3. 1.269
4. 0.966
5. 0.714
What do you think ?
M/T 24.5x8x15.i had the m&h you are speaking of and had big traction problems.i am using 26x8 goodyears now and traction is not a problem, but clutch is.once i get the right clutch,it will be axles.i think the m/t are the best to go with.
I chose the MH 24.5x8.5x15 to clear my ITR brakes on my EK. I have the Weld Drag Pro rims. FYI-I got them from a domestic dealer for about 100 less then any other import specialist. The ITR pattern ended up being the same as a domestic one is.
Jason
Jason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR »</TD></TR><TR><TD CLASS="quote">M/T 24.5x8x15.i had the m&h you are speaking of and had big traction problems. </TD></TR></TABLE>
you had traction issues with 9.2 " wide M&H , and you recommend me 8" wide M/T is that correct ? Could you explain why ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR »</TD></TR><TR><TD CLASS="quote">M/T 24.5x8x15.i had the m&h you are speaking of and had big traction problems.i am using 26x8 goodyears now and traction is not a problem, but clutch is.once i get the right clutch,it will be axles.i think the m/t are the best to go with. </TD></TR></TABLE>
Did you use the right size rim, that M&H recommends?
Suzukii
Sep 26, 2006 06:33 AM
