Can I make it to the 10's
Old Jul 12, 2004 | 05:39 PM
meanteg's Avatar
New User
Default Can I make it to the 10's
Car: 97 integra GSR turbo dynoed at 509 whp / 329 tq.
Tranny :LS
Best time with 22x8x15 slicks: 11.36 @ 131.
The car spun until the 1/8 mile mark.
So I figured I needed more traction.
I tried 26x8.5 x 14 slicks .. best e.t: 11.64 @ 128
The problem is the long *** gears with the LS tranny, the problem gets a lot worse with the 26'' slicks
So, I have two choices : either I get a SiR tranny and keep the 26'' slicks or I go with 24 x 9.2 x 15 slicks and keep the LS.
What do you think ?
Old Jul 12, 2004 | 07:31 PM
Jared's Avatar
Default Re: Can I make it to the 10's (meanteg)
get a b16 trans with the tall slicks and go from there. a 25x8.7x13 will probably work best. what are you shifting at? what does the car weigh? with the proper setup 500whp should let you run high 10s.
Old Jul 12, 2004 | 08:33 PM
meanteg's Avatar
New User
Default Re: Can I make it to the 10's (Jared)
I need 15 '' minimum because I got 11'' brakes.
I shift at 9000 rpm, on the balance the car weights 2660 without driver.
24'' slicks / LS tranny, or 26'' slicks / SiR tranny ?
Old Jul 12, 2004 | 09:02 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Get a b16 tranny... id suggest 25's, but if u cant fit them, then there goes that idea..
Old Jul 13, 2004 | 08:12 AM
tygsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meanteg &raquo;</TD></TR><TR><TD CLASS="quote">I need 15 '' minimum because I got 11'' brakes.
24'' slicks / LS tranny, or 26'' slicks / SiR tranny ? </TD></TR></TABLE>
You might try a MH 24.5x8.5x15..I believe they make that size. I would get a GSR tranny personally..
Old Jul 13, 2004 | 08:27 AM
G
sh!t happens.
Default Re: Can I make it to the 10's (tygsr)
get a gsr tranny or a b16sir tranny. the ls trany i never liked. i have b16 tranny in my teg and i love it.
Old Jul 13, 2004 | 08:32 AM
miller's Avatar
Default Re: Can I make it to the 10's (G"UNIT)
get yourself a b16 tranny and the car will go tens......
Old Jul 13, 2004 | 09:20 AM
b18psi's Avatar
Wouldn't the shorter gears make you use fifth gear in the quarter?
Old Jul 13, 2004 | 09:29 AM
HT's Biggest Loser
Default Re: (b18psi)
not revving to 9000rpm
Old Jul 13, 2004 | 01:39 PM
londa hover's Avatar
Default Re: (SIXTYdashONE)
how is it that you can go 140mph and only be at the end of 4th gear? the gsr tranny can only go to 142mph
Old Jul 13, 2004 | 02:08 PM
g2turbo's Avatar
Default Re: (londa hover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by londa hover &raquo;</TD></TR><TR><TD CLASS="quote">how is it that you can go 140mph and only be at the end of 4th gear? the gsr tranny can only go to 142mph </TD></TR></TABLE>
rev higher
Old Jul 13, 2004 | 02:17 PM
TurboLSVtecTeg's Avatar
Default Re: (g2turbo)
Thats on stock tires which are something like a 22 or so inch slick. Now throw on a 26" slick and the gearing is longer. I think with a 9K redline the gsr tranny will go out to 160's in fourth gear if i remember correctly. They have a tire/speed calculator out there somewhere for honda's. I forget the site.
Sal
HT's Biggest Loser
yep, rev higher, and you can go alot faster then 142mph bud..
Old Jul 13, 2004 | 02:26 PM
g2turbo's Avatar
i am setting my car up with a cable b16 tranny and reving to car to 9800 25" slick
Old Jul 13, 2004 | 02:31 PM
bomber's Avatar
Default Re: (TurboLSVtecTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLSVtecTeg &raquo;</TD></TR><TR><TD CLASS="quote">Thats on stock tires which are something like a 22 or so inch slick. Now throw on a 26" slick and the gearing is longer. I think with a 9K redline the gsr tranny will go out to 160's in fourth gear if i remember correctly. They have a tire/speed calculator out there somewhere for honda's. I forget the site.
Sal</TD></TR></TABLE>
Does anyone have the link to this site? I have done a few calculators that you need to enter in all the numbers which kind of sucks...but I have seen one that already has all the honda trannies in a dropdown box which is nice. Anyone know what site I am talking about?
Old Jul 13, 2004 | 02:32 PM
THCk20eg's Avatar
go buy a b16 tranny and a new set of slicks. and try both ways.
Old Jul 13, 2004 | 02:52 PM
XXXRacing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">i am setting my car up with a cable b16 tranny and reving to car to 9800 25" slick</TD></TR></TABLE>
You should be able to go 145-148 at 9800
ashb82
Aug 27, 2011 06:06 PM
LSVTEC 91 Civic
18
Oct 31, 2005 08:17 AM
meanteg
Oct 9, 2003 07:00 PM
meanteg
Sep 9, 2003 07:37 AM
EH2LS
Sep 8, 2003 02:15 PM
