just installed my $99 code alarm 2 way pager remote start alarm w/manual trans.
Old Sep 6, 2003 | 08:41 PM
pickup1's Avatar
Default just installed my $99 code alarm 2 way pager remote start alarm w/manual trans.
took awhile but it all works.didnt bypass anything,so it wont start without the clutch pushed in.bought this alarm new off ebay for $99 + 12 shipping.does everything but wipe my ***!!,but it doesnt have carjacking though.has the 2 way pager remote with 1000 ft range and a 4 button 1 way remote also. ...Features: *1 two way 3 Button Remote Control and 1 One way 4 Button Remote Control *Six Channel Code Learning Programmable Receiver *External Superheterodyne Receiver Antenna *Single or Two User Programmable W/Separate Control Outputs *Single Button Lock/Unlock or Seperate Button Lock/Unlock or both *Remote Keyless Entry with Optional Access Guard *Selectable Manual Override Mode *New Enhanced Panic Feature *Smart Disarm *Selectable Automatic Timed Start Mode *Adjustable Shock Sensor Via The Transmitter *Sage Start Output Controlled for Channel 3 *Remote Panic In all modes *Improved Custom Code Override, User Selectable and Programable *Protected Push Button Valet/Override Switch *7 Function LED Alarm/Disarm/Zone 1/Zone 2/Zone 3/ Valet/ Arming *Intrusion Alert with Memory *Instant Siren Activation 2-Way Paging Features
Fully Animated LCD Graphics Display Armed, Disarmed, Zone Violation and Vehicle Running After Remote Start
Remote Starting with Built-In Relays (requires automatic transmission and fuel injection)
Double Push Mode with Safe Start
Idle, RPM, Crank, and Brake Monitors
Programmable Crank and Idle Times
Gas or Diesel Operation
One 4-Button, 2-Way Confirming Transmitter
Illuminated LCD Display
Alarm Zone and Trigger Indication
Parking Meter Timer and Clock
Superheterodyne RF Technology with External Antenna
Up To 1000 ft. (1/3 Mile) Transmitter Range
One 4-Button Icon Transmitter
"City Mode" Plug-In Shock Sensor
Remote Adjustable
4-Modes of Operation
2-Stage Trigger with Warn Away
Built-In Parking Light Flash
Built-In Starter Disable
Optional Remote Door Lock and Unlock (may require additional relays)
Optional Illuminated Entry (may require additional relay)
Smart Disarm
Enhanced Panic Mode
Dual Vehicle Capable
Optional Window Roll-Up and Roll-Down (may require additional relays)
Optional Remote Trunk Release (requires factory electronic trunk release)
so far works good.i'll keep ya'll posted in case its a piece of ****!!
Old Sep 7, 2003 | 09:06 AM
clm's Avatar
clm
Default Re: just installed my $99 code alarm 2 way pager remote start alarm w/manual trans. (pickup1)
Sounds like a decent alarm. How was the install?
I could use an alarm, but don't want to spend too much on one. To me thney all do the same, just hide everything.
Keep us updated!
Old Sep 7, 2003 | 08:17 PM
VTECorona's Avatar
Default Re: just installed my $99 code alarm 2 way pager remote start alarm w/manual trans. (clm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clm &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a decent alarm. How was the install?
Keep us updated!</TD></TR></TABLE>
Old Sep 7, 2003 | 08:23 PM
ATF Kuk's Avatar
i know that alarm, thats the code alarm tw-2. im gonna get the code alarm tw-1 which is even better than that alarm.
Old Oct 9, 2003 | 10:31 PM
sting94112's Avatar
Default Re: just installed my $99 code alarm 2 way pager remote start alarm w/manual trans. (ATF Kuk)
how is the alarm?
Old Oct 9, 2003 | 10:56 PM
Teamhonda5's Avatar
Default Re: just installed my $99 code alarm 2 way pager remote start alarm w/manual trans. (sting94112)
hey guys, 99 sound good, but once you go into buildings you lose reception and the two pager function is useless. if you want a good pager alarm system get the matrix rs3, rs3.5, viper 860xp, python 860xp, they use a strong fm signal, unlike the cheap copies that uses am signal.
_________
David
Audio Performance & Security
http://www.audioperformance.cjb.net
510-670-1390
Old Oct 9, 2003 | 10:57 PM
sting94112's Avatar
Default Re: just installed my $99 code alarm 2 way pager remote start alarm w/manual trans. (Teamhonda5)
is tw1 better than tw2?
Old Oct 9, 2003 | 11:30 PM
pickup1's Avatar
yea the range aint that good!!i wanted the remote start to fuction as a "turbo timer".it works fine.and i just checked back with the person i got mine from,and now he's got 1 for 60 plus shipping!!
Old Oct 10, 2003 | 12:21 AM
sting94112's Avatar
so did u get the remote start to work? who is the guy selling it?
Old Oct 10, 2003 | 08:12 AM
ATF Kuk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teamhonda5 &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, 99 sound good, but once you go into buildings you lose reception and the two pager function is useless. if you want a good pager alarm system get the matrix rs3, rs3.5, viper 860xp, python 860xp, they use a strong fm signal, unlike the cheap copies that uses am signal.
_________
David
510-670-1390</TD></TR></TABLE>
so are u saying that code alarm is a cheap copy? if so then tell my why my TW-1 can go up to 2 miles? i dont think the clifford rs3, rs3.5, viper, python can go up to 2 miles. lifetime warranty also
Old Oct 10, 2003 | 08:49 AM
Quad-Damag's Avatar
dude trust me the TW-1 can go up to 2 miles, thats BULL ****, if u are on a clear feild, but if u are inside the mall or at the movies, have a firend set off your alarms, i would bet u don't get paged even beeing about 1/2 a mile away from your car, they are so over rated, the viper is ok, i have been paged inside the movies before.
Also with that ebay alarm, the only real thing u got was Built-In Starter Disable, and Alarm Zone and Trigger Indication,
WOW so easy to bypass, that alarm is wack, u didn't get any good extras, just a pager that won't page u when ur out of range, good buy
u have no glass sensor
u have no tilt sensor
u have no wireless imoblizer (spelling?)
u have no fuel cut off
no blackjax my fav anit theft THING EVER MADE(should of saved up for a cliffort)
u should look into getting a fuel cut off, becuase that kill switch isn't going to stop 2 many thives, just find where u wired it on your ingination wire, and just rip it out and rewire, about under 1 min and he is done doing that, and driving off with ur car, the 1/3 mile range is crap, like i said test it far away inside a building u won't get paged watch.
Old Oct 10, 2003 | 09:07 AM
ATF Kuk's Avatar
Default Re: just installed my $99 code alarm 2 way pager remote start alarm w/manual trans. (Quad-Damge)
u sound like an idiot. first of all, u know nothing about the alarm and u flame on it. second, u cant spell for ****. i didnt even finish high school and i spell better than u do.
hahhahahaaha even in ur own sig. u spelled special speical.
Old Oct 10, 2003 | 01:40 PM
is3oo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge &raquo;</TD></TR><TR><TD CLASS="quote">dude trust me the TW-1 can go up to 2 miles, thats BULL ****, if u are on a clear feild, but if u are inside the mall or at the movies, have a firend set off your alarms, i would bet u don't get paged even beeing about 1/2 a mile away from your car, they are so over rated, the viper is ok, i have been paged inside the movies before.
u should look into getting a fuel cut off, becuase that kill switch isn't going to stop 2 many thives, just find where u wired it on your ingination wire, and just rip it out and rewire, about under 1 min and he is done doing that, and driving off with ur car, the 1/3 mile range is crap, like i said test it far away inside a building u won't get paged watch.</TD></TR></TABLE>
Why do you hate on every other alarm besides the Clifford? Couldn't you just get those extra features (glass sensor, tilt sensor, etc ..) at any car stereo shop? I know you can because I just did the other week. I've tested out my pager unit on my APS_996 as well and the range is great. Sure it probably won't reach me when I'm deep inside a shopping mall a mile away, but I'm not expecting it to. Hell, I'd be lucky to even have any reception with my cell phone (T-Mobile sucks *****). My main concern is when I'm inside nearby buildings (stores, movies, the gym, etc..). I haven't had any false alarms yet and I think it was a great buy for only $150. They sell this same alarm for over $400 at a retail shop.
Old Oct 10, 2003 | 06:59 PM
RiceRacist's Avatar
Default Re: just installed my $99 code alarm 2 way pager remote start alarm w/manual trans. (Type-Rizzle)
How do you install a glass sensor? How does the alarm no that the car was even bumper on say the rear quarter panel. Could someone point me out to a fairly cheap alarm with a window sensor, dont care about fuel cut off or anything because Im canadian and cars dont get stolen around here, just audio equipment.
Hopefully a good alarm with some things like pager,window alarm,body hit alarm
thanks
Old Oct 10, 2003 | 07:21 PM
ATF Kuk's Avatar
another type r guy... u must be the like the 6th type r guy in here. type r guys are up and coming into the audio/security forum. now i dont feel so lonely here.
Old Oct 10, 2003 | 07:56 PM
HondaDriver4Life's Avatar
The TW-1 and TW-2 are rebadged Audiovox Prestige Alarms (Audiovox bought Code Alarm a while back). The TW-2 is similar to the APS-995 and TW-1 is similar to the APS-996. These alarms are very good.....just as capable as any other 2-way system out there. Once again, it all comes down to the install.
Old Oct 10, 2003 | 07:58 PM
vteg's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATF Kuk &raquo;</TD></TR><TR><TD CLASS="quote">another type r guy... u must be the like the 6th type r guy in here. type r guys are up and coming into the audio/security forum. now i dont feel so lonely here.</TD></TR></TABLE>
You guys got tired of listening to just vtec
Old Oct 10, 2003 | 08:34 PM
ATF Kuk's Avatar
Default Re: just installed my $99 code alarm 2 way pager remote start alarm w/manual trans. (vteg)
u have pssshhhh to listen to... i want boost in my type r. too bad i cant afford it.
Old Oct 10, 2003 | 08:40 PM
rjr162's Avatar
I say BS to this also. Even the old analog cordless phones with worked in the 434 mhz range (same as most alarms) only ranged 300 feet or so, give or take. Unless you're using some directional antenna or something of that sort *and* increase the power beyond what FCC would allow...
Hell I have a 1 watt GMRS radio, and my friend and I could barely get a mile out of the damn things, unless he was up on the mountain-top and I was somewhere in "line-of-site", and then we could pull off decently close to the 5 mile range they claimed.
Park your car, and have someone drive @ 45 mph for a little over 2 and a half minutes and you'll be two miles away from your car. See if it works, highly doubtful.
Old Oct 10, 2003 | 09:35 PM
ATF Kuk's Avatar
Default Re: just installed my $99 code alarm 2 way pager remote start alarm w/manual trans. (rjr162)
im an authorized dealer for DEI, which owns clifford, viper, python, etc. but for some reason i chose this over all the alarms i sell. keep in mind that i sell all of the DEI brands, except for a few. so this is not a biased decision because i like one company over the other. i bought it for a reason, the reason was simply because it was better overall and had the longest range. i pretty much know about all the alarms i sell and all of them have flaws in some way, some more than others.
the 2 mile claim wasnt made by code alarm themselves. that is past FCC regulations like u said. it was made by installers and people who know about the alarm. when the alarm comes new right out of the box, it has a 800-1200m range. u move a jumper setting and it can go up to 2 miles. i didnt say for sure, depends on things between the transmitter and pager. i never said it will, i said it can go up to 2 miles.
Old Oct 10, 2003 | 09:54 PM
VTECorona's Avatar
So what's the verdict? Good or bad alarm? If they are going for that cheap I may just have to get one.
ATF Kuk: what does the best clifford alarm go for (the one with a pager and stuff). A friend of mine owns a shop and can get me it at cost but have no clue of the ballpark range.
Old Oct 10, 2003 | 11:38 PM
ATF Kuk's Avatar
Default Re: just installed my $99 code alarm 2 way pager remote start alarm w/manual trans. (VTECorona)
just ask ur friend how much it is. dealers prices are confidential, im sorry but i cannot release that info
Old Oct 11, 2003 | 06:58 PM
slowhatch4now's Avatar
yea looks like a good alarm, the reason i didnt buy from ebay is because i went to a few shops around the way and they only said the best is made by DEI. I have decided to just get one of those soon. with power locks on both doors, a hood sensor, hatch sensor, and all those main sensors, with install he said it would be about 380 . the whole pager alarm thing is BS, becuase if you leave your car some where and walk away, then some one comes and breaks your window and takes stuff inside, like vafc or something valuable, they can break the window, take the **** and be OUT by the time you come back running to your car. i mean it would help somewhat if you were near the car , or had lojack so that you could call them as soon as your car was gone , but with low jack damn that would be EXPENSIVE and still not be 100 % thieve-proof. best thing, get a BIG *** pit bull and leave that in your car. PEace
Old Oct 11, 2003 | 09:35 PM
lilbennyxx's Avatar
Thats a really good alarm. Props. Damn hard to install those alarms
smoked08
Audio / Security / Video
Apr 28, 2011 02:12 PM
Dr. Willy
Aug 11, 2008 12:53 AM
inh
May 29, 2008 01:32 PM
VN712
Feb 11, 2007 08:31 AM
