worn valve guides make ticking noise??????????
Old Sep 6, 2003 | 06:10 PM
hybridb18's Avatar
Default worn valve guides make ticking noise??????????
do worn valve guides make ticking noise's? I have a weird ticking noise coming from my b16 head. it ticks nomatter if the engine is warm or cold. it does it usually at lower rpm's, mostly at idle. It isnt a constant noise, it comes and goes
Old Sep 6, 2003 | 06:29 PM
mr.beeks's Avatar
Default Re: worn valve guides make ticking noise?????????? (hybridb18)
have you adjusted it?
also think about replacing the springs..
Old Sep 6, 2003 | 06:40 PM
hybridb18's Avatar
Default Re: worn valve guides make ticking noise?????????? (francisco flores)
its got brand new itr valvesprings, and i adjusted the valves 4 times now
Old Sep 6, 2003 | 07:13 PM
brainwo's Avatar
New User
Check LMA, replace with ITR ones.
Old Sep 6, 2003 | 08:30 PM
sirminder's Avatar
Default Re: worn valve guides make ticking noise?????????? (brainwo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brainwo &raquo;</TD></TR><TR><TD CLASS="quote">Check LMA, replace with ITR ones.</TD></TR></TABLE>
or GSR LMA's
Old Sep 7, 2003 | 12:34 AM
MikeSarr_GSR's Avatar
Default Re: worn valve guides make ticking noise?????????? (sirminder)
or any LMAs that dont bottom out because they B beat up
iamthefollower
Apr 23, 2012 04:07 PM
B20BV
Dec 14, 2007 11:55 PM
.I.Need.Money.
22
Nov 8, 2007 05:47 PM
hatchdrvr
May 27, 2004 06:00 PM
FMIDRC Racer
13
Oct 20, 2003 07:57 PM
