lsvtec buildup
Old Sep 6, 2003 | 05:26 PM
JBk24crx's Avatar
Default lsvtec buildup
Is 240+whp possible with this setup.
pr3 head-p&p portflow-welded combustion chamber-portflow valvetrain and skunk2 stage 2 cams and cam gears-jg edelbrock intake manifold portmatched-70mm throttlebody-rc 440 injectors-ericks racing side exit header.
b18a1 block-bored 86mm-decked-honed-IBspec super dupers 14:1cr with raised wrist pins-eagle rods-polished and knife edged crank-balanced and blueprinted-GE sleeves.
tranny-S1
ecu-p28 with hondata s200
Old Sep 6, 2003 | 06:53 PM
91tegrals's Avatar
i would say so but why not go with a b20 block instead of a b18...
Old Sep 6, 2003 | 07:22 PM
skribblah's Avatar
Default Re: (91tegrals)
toss thos super duper wooper pistons and get endyn rollerwaves...
Old Sep 6, 2003 | 09:45 PM
sickness's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegrals &raquo;</TD></TR><TR><TD CLASS="quote">i would say so but why not go with a b20 block instead of a b18...</TD></TR></TABLE>Because if he is going to run an 86mm bore he is going to have to sleeve either way and b18a blocks are typically way cheaper than b20 blocks.
240whp SHOULD be attainable with that set up.
Kim Bay
11
Aug 17, 2009 07:47 AM
johnnyjennings
13
Feb 15, 2008 03:20 PM
SolAssassin
Oct 21, 2007 05:07 PM
SuperImport
Mar 18, 2005 12:42 PM
Yangsta_P
Aug 25, 2004 10:59 PM
