b18cr block.. how did i crack one?
Old Sep 6, 2003 | 10:27 AM
c3p3r's Avatar
Default b18cr block.. how did i crack one?
Hey Guys,
My mechanic has told me that I've cracked my JDM Type R block.. he didn't say much about how this happened.. he just said that it's happened.. Firstly, my head gasket blew.. and when they replaced the gasket, the engine wouldn't crank or hold water... he says the block must be cracked somewhere.. firstly, how can this happen? and anyone got any ideas about why the f... this happened? i mean i'm not doing anything special.. I just have headers and exhaust.. I've just had the motor re-done, all the bearings, seals and gaskets.. any idea what could have been or not could have been done which caused this???
Your replys will be most appreciated..
Paul.
Old Sep 6, 2003 | 05:48 PM
machine4321's Avatar
i would be very leary untill you see a crack in it or he shows you
he mught want your block
Old Sep 6, 2003 | 06:04 PM
Wazup's Avatar
Default Re: (machine4321)
first, you have to stop saying "firstly".
Old Sep 6, 2003 | 07:29 PM
Mohudsolo's Avatar
Default Re: (Wazup)
I'd want to know where the block is cracked and some idea why the head gasket blew. On a stock motor without overrevving or cooling system problems, I would not expect the gasket to blow out. There could be some internal mechanical problem that started it all. Basically you need a bunch more info.
Was this motor yours from new or is it a used import? If imported, you do not know what kind of life it led before or if it had some internal mods. You need a teardown to evaluate what is left. If only the cylinder is cracked, it should be possible to re-sleeve it.
Old Sep 7, 2003 | 02:58 PM
AngryTroll's Avatar
Default Re: (Wazup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wazup &raquo;</TD></TR><TR><TD CLASS="quote">first, you have to stop saying "firstly".</TD></TR></TABLE>
LOL.
Old Sep 7, 2003 | 03:02 PM
HXMan's Avatar
Default Re: b18cr block.. how did i crack one? (c3p3r)
Might want to check your head for flatness.
Old Sep 7, 2003 | 04:28 PM
Patch's Avatar
Default Re: b18cr block.. how did i crack one? (HXMan)
Overheating would cause the blown head gasket and the cracked block.
Old Sep 7, 2003 | 04:38 PM
T4eg's Avatar
Default Re: (Wazup)
lol
Old Sep 7, 2003 | 08:02 PM
TeStUdO's Avatar
Id definitely ask to see the crack in the sleeve. Sounds kinda odd, I doubt you cracked it. I would check the head to see if its warped. It might need to be milled a little.
Old Sep 7, 2003 | 08:27 PM
IMALLSLO's Avatar
If anything the sleeves have cracked and this is a easy fix by resleaving it. Better solution then tossing away a rebuildable block. Have the mechanic show you the damage and if he cant get the car out of there and take it to someone that knows what they're doing and knows how to troubleshoot a coolant/overheating problem.
dantamparacer
Apr 17, 2012 07:37 PM
VTgringo
Aug 12, 2004 06:29 AM
Prelude Vtec 23
May 15, 2003 08:12 AM
turboex
Jan 22, 2003 02:58 PM
