Inserting a fuel line
Old Sep 6, 2003 | 08:06 AM
User 5426's Avatar
Default Inserting a fuel line
This is not for my honda, it's for a truck. I am changing the fuel lines to a truck. I removed the old rubber fuel line from the tank and another the area where it goes to a metal fuel line. I would like to know if there is a special tool that stretches the fuel line hoses to make them install. The metal fuel line has a flared head and the akward angle makes it impossible to push by hand. Is there a lube?
any suggestions will greatly be appreciated.
Old Sep 6, 2003 | 09:13 AM
User 5426's Avatar
come on. I know that someone knows of a tool or a technique to install a rubber fuel hose over a flared tip metal line. I just needed to change the rubber lines but I can't install it.
Old Sep 6, 2003 | 12:54 PM
madslackin's Avatar
Default Re: (SeaQuake)
Try any lubricant like WD40 and spray the rubber hose and the metal pipe. That makes it a ton easier than trying to do it dry.
Old Sep 6, 2003 | 07:44 PM
User 5426's Avatar
Thanks for the help. Turns out that I ended up fitting a 1/4 inch tube on a 5/8 inch pipe. the real size was an easy fit.
vectorsolid
35
Aug 19, 2013 09:35 PM
blue92da
Jun 22, 2007 02:11 PM
meancivicsi
Jun 19, 2007 07:31 AM
h22acivichybrid
Jun 14, 2004 03:20 PM
Lyrikz
Sep 30, 2003 09:10 AM
