new valve cover + old valve cover gasket???
I am putting a new valve cover on my motor, and i am using the old valve cover gaskets. Should i use gasket sealer in there too to prevent leaks? If so , where should i apply it, if not all around?
ive reused my valve cover gasket about 3 times ...i would reccomend a new one but i didnt have any problems reusing mine
the valve cover gaskets are not a traditional "gasket" they're more of a seal. Just make sure both surfaces are clean and the "gasket" is not beat up or torn etc...
It can be reused, and if you replace it everytime you pop off the valve cover, you either
A. buy into too much bs
B. have more money than brains
C. both a & b
C. both a & b
depo
Mar 23, 2019 09:37 PM
Shaguar47
May 28, 2007 08:47 AM
