12 ton press... wheeel bearings?
I've used a 12-ton press before, although i've never tried to press out a wheel bearing. I'm going to vote no on this one. I know most mechanics shops use 50ton presses to do that type of work.
Danny
Danny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion »</TD></TR><TR><TD CLASS="quote">will a 12 ton press be enough to press out and replace wheel bearings?</TD></TR></TABLE>
It should do it, unless you get a really nasty tight one.
depends really. I've had them come out with a benchtop hand press and I had them where the only way to them out was a 1.5in steel socket and a 20lb sledge. Sometimes you just can't get he casing in the right position in the press or else the press will snap the casing like a twig.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6Elmo »</TD></TR><TR><TD CLASS="quote">I've used a 12-ton press before, although i've never tried to press out a wheel bearing. I'm going to vote no on this one. I know most mechanics shops use 50ton presses to do that type of work.
Danny</TD></TR></TABLE>
50 ton!! wow! i've never seen those, we have a 12 ton at the shop, and when we have nasty work that requires more we send it to a 20 ( i think) ton press and never had a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZERO »</TD></TR><TR><TD CLASS="quote">
50 ton!! wow! i've never seen those, we have a 12 ton at the shop, and when we have nasty work that requires more we send it to a 20 ( i think) ton press and never had a problem.</TD></TR></TABLE>
Yea, we have a 10 ton, it's good for about 98% of them. A BFH will usually get the rest of them.
immalooser
Feb 28, 2006 12:44 AM
just turn the valve
