tranny problem help if u will
Old Sep 5, 2003 | 05:05 AM
silverCRXTC's Avatar
Default tranny problem help if u will
ok i got a b16a with a centerforce clutch in a crx, the other day after class it wouldnt go into gear except with the car off. Went home and adjusted the cable and drove it around, it was fine, now this morning i start it up to goto work, and it starts the same ****, then an hour later (not changing a thing) it works fine (well almost still a tad bit ruff)
what u think?
Old Sep 5, 2003 | 06:18 AM
JDMCRX's Avatar
Default Re: tranny problem help if u will (silverCRXTC)
you got clutch disangaugement probs. when the clutch was done either the splins were niot cleaned and greased well or u bent a finger on the pressure plate.
michjdm
Aug 5, 2009 12:42 PM
PINKS
Jan 14, 2006 01:44 PM
PINKS
12
Jan 14, 2006 06:05 AM
PINKS
Jan 13, 2006 11:17 PM
BoostedED9
Nov 13, 2002 05:47 AM
