Which is the best B-series head-B16A,B18C1,B18C5
Old Sep 4, 2003 | 08:08 PM
crxhybrid1320's Avatar
Default Which is the best B-series head-B16A,B18C1,B18C5
Which is the best B-series head-B16A,B18C1,B18C5?
I know the B16 and Integrea Type R heads are both PR3 heads, but is the ITR head ported and polished at all or is the only difference in the valvetrain and ITR cams?
Any advantages on the B18C1 head besides the slight higher compression?
JG ELDEBROCK B18C1 GSR MANIFOLD USED FOR 2,000 MILES $230
Old Sep 4, 2003 | 09:09 PM
5thgencivic's Avatar
Default Re: Which is the best B-series head-B16A,B18C1,B18C5 (crxhybrid1320)
I believe the type r head flows better than the gsr. So it's not just the cams and valvetrain that are different.
Old Sep 4, 2003 | 09:16 PM
str8drift's Avatar
b16 has better flow characteristics. so some ehat has port and polish. i believe.
Old Sep 4, 2003 | 09:17 PM
MikeSarr_GSR's Avatar
Default Re: Which is the best B-series head-B16A,B18C1,B18C5 (5thgencivic)
stock peice. fun. take your head to a shop and have it flowed with the cams you are going to use with the manifold and TB you are using. if you have a need for quality or CFMs, take it to someone to have it done. you will see optimal results.
stock heads flow so much the same its almost a waste of your time to invest in anything before that is done. go to joe alanzis' page. he has head benchmarks on it for you to browse
Old Sep 5, 2003 | 10:39 AM
Default Re: Which is the best B-series head-B16A,B18C1,B18C5 (MikeSarr_GSR)
I think the pr3 head flows better.
Whats the difference between the b16 pr3 and b18c5 pr3 heads besides the valvetrains?
Old Sep 5, 2003 | 10:46 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhybrid1320 &raquo;</TD></TR><TR><TD CLASS="quote">I think the pr3 head flows better.
Whats the difference between the b16 pr3 and b18c5 pr3 heads besides the valvetrains?</TD></TR></TABLE>
the B18C5 or type-R head has a slight port job on the intake side (and exhaust side if i'm not mistaken), besides having slightly better valvetrain, lost motion assemblies, and camshafts. that's about it though.
Old Sep 5, 2003 | 11:05 AM
Davep's Avatar
Here is the bowl port on an ITR head. As you can see it's minor work and the rest of the runners remain untouched.
Old Sep 9, 2003 | 08:48 AM
oday's Avatar
I thought a type r head came with a 3 angle valve job as well???
Old Sep 10, 2003 | 04:43 PM
Default Re: Which is the best B-series head-B16A,B18C1,B18C5 (Davep)
I think every honda head has three angles. These angles include where the valve seats against, one above that and one below that angle.
I may be wrong though!
Old Sep 10, 2003 | 07:21 PM
fox297's Avatar
I hear people say that the gsr port runner is different from the pr3. Anyone have any details?
highrev1987
Jun 22, 2007 05:00 PM
crackerjacker006
Apr 9, 2007 12:31 AM
wantboost
Aug 16, 2004 06:57 AM
the DA in HONDA
Jul 26, 2004 05:13 AM
