Axle question
Old Aug 18, 2001 | 12:50 PM
nugget8000's Avatar
New User
Default Axle question
I will be putting in a new clutch and flywheel next weekend (finally, been waiting all summer) and I was wondering if I have to take the spindle nuts off both sides or just the passenger side. If I do, would this spindle nut be the same as those on any HONDA name vehicle (closest acura dealer is 120 miles, I REALLY REALLY want to get this on next weekend so I can possibly spend my last week of vacation out of town). I know I don't have to take the axles off, but the experience will be useful. My car is a 94' GS-R. Any help is greatly appreciated, thanks in advance.
Old Aug 18, 2001 | 02:50 PM
G's Avatar
G
Default Re: Axle question (nugget8000)
I've used a honda spindle nut on my xGSR. I don't know what car it is off of. I have also re-used the original, but I do not reccomend it......
Old Aug 18, 2001 | 11:34 PM
sgT's Avatar
sgT
Default Re: Axle question (G)
32mm nut. Get a REAL BIG breaker bar or air tools are a must.
Its quite alright to reuse them, as long as you put them on tight you will be fine.
Old Aug 19, 2001 | 07:06 PM
nugget8000's Avatar
New User
Default Re: Axle question (sgT)
Does anyone know if I have to take the spindle nuts, ball joints, etc. off both sides or just the passenger side. I can't find anything that specifically says to do it either way in The Great Book of Knowledge. My sense tells me that I would have to take both sides off because it seems it would be a bitch trying to hammer the axle out of the drivers side when it's trapped between the differential and knuckle, but at the same time I don't want to do unnecessary work (from my observations people tend to have trouble removing the ball joints). I also want to be prepared. Thanks for the help so far.
Old Aug 19, 2001 | 07:17 PM
BreakStuff's Avatar
New User
Yes..you should do both sides.. If you try to do it with one side intact you will most likely end up seperating your axle from outboard/inboard joint.. thus blowing the thought of "unnecesary" work out the door.. and btw....don't hammer axles..they really don't like that when that happens...
MadVladCivic
May 5, 2015 03:56 PM
greyEG
Jun 29, 2014 05:15 PM
andrew55ap
Honda CR-V & Element
Oct 20, 2011 11:41 AM
tkosmith
53
May 2, 2006 08:32 AM
93egsi
14
Jul 9, 2004 10:10 AM
