W.T.F.......slipping clutch after new replacement and flywheel
Old Sep 4, 2003 | 07:31 PM
matt_tuck's Avatar
Default W.T.F.......slipping clutch after new replacement and flywheel
I bought a new exedy clutch, had the flywheel machined, and bled it properly. Slave cylinder seems to remain pressurized even when pedal isn't even being pressed. What would not allow for the slave cylinder to relieve pressure on the clutch arm?
Old Sep 4, 2003 | 07:41 PM
AndyD's Avatar
Default Re: W.T.F.......slipping clutch after new replacement and flywheel (matt_tuck)
So when you drive your car...the clutch will slip when driving it normally?? Hard??
How did the clutch fluid look while you were bleeding it??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_tuck &raquo;</TD></TR><TR><TD CLASS="quote">I bought a new exedy clutch, had the flywheel machined, and bled it properly. Slave cylinder seems to remain pressurized even when pedal isn't even being pressed. What would not allow for the slave cylinder to relieve pressure on the clutch arm? </TD></TR></TABLE>
Old Sep 4, 2003 | 07:51 PM
NXLude's Avatar
is it slipping during normal driving or under hard acceleration? Did you break it in at all?
Old Sep 4, 2003 | 08:52 PM
CHK4TIX's Avatar
Default Re: (NXLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXLude &raquo;</TD></TR><TR><TD CLASS="quote">is it slipping during normal driving or under hard acceleration? Did you break it in at all?</TD></TR></TABLE>
yah, did you do the average 500-1000 mile break in period
cdees
Transmission & Drivetrain
19
Jan 7, 2010 09:15 AM
blink_977
Jun 4, 2009 01:31 AM
mrccupid3
May 8, 2009 07:09 AM
allshownogo
33
Mar 19, 2009 01:00 PM
yOnKiNaToR
Feb 1, 2006 04:59 PM
