wat the heck is the spring rate?
i just purchased a set of Apexi N1 Type V Dampers for my car and i was wondering what the spring rates for the front and rear are. Before some jerk yells "search" at me i want you guys to kno i did run several, but could not find this data. I'm looking for info on the 2000 spec N1's. Thanks
are there #'s on the springs?? they are probobly in kg/mm...they should look like this.
EDIT: holy chit the pic is HUGE sorry
I'm sure apex'i isn't Identical to my GC's but heres a recent thread created by myself where I had the same ?
https://honda-tech.com/zerothread?id=596640
I found the answer to my problem listed above from Tyson..
here is the coilover FAQ written by him.
http://www.norcalcrx.org/tyson/coilover.html#05
hope this helps..
hope this helps..
hmm thanks. i looked up the front and rear spring rates in the japanese manual and it says 16kgf/mm front and 6kbf/mm rear. the conversion says that im running 900f/400r. will this destroy my chassis if i use this car for daily driving?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsk62 »</TD></TR><TR><TD CLASS="quote">hmm thanks. i looked up the front and rear spring rates in the japanese manual and it says 16kgf/mm front and 6kbf/mm rear. the conversion says that im running 900f/400r. will this destroy my chassis if i use this car for daily driving?</TD></TR></TABLE>
wow, that front rate seems amazingly high...that would contribute to some serious understeer..you sure you got the front rate converted correctly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsk62 »</TD></TR><TR><TD CLASS="quote">im pretty sure its right. the front springs are 1184kg/74mm which is 2610lbs/2.9in which simplifies to 16kg/mm or 900lbs/in.</TD></TR></TABLE>
jeez, maybe you should consider putting those in the rear...that would make your car more neutral, if not oversteer quite a bit.
Are they installed yet? if so how does your car behave?
even though the front is really stiff i don't have understeer problems really. i installed them yesterday and the car handles like a dream. i want to get them corner balanced but no $ yet...
KetteringITR
May 27, 2005 10:55 AM
njandrewg
Apr 6, 2005 02:04 PM
