A/C compressor issues I need A/C i`m in louisiana and today were 91 degrees
i have a 93 cx with a swap, the old compressor bolted on the delsol bracket bat it is a R-12 system by a month ago I had to change it to R-134a since it was low on freon,
i know a friend that fited a R-134a compressor on the old system with just some bigger o-rings, and i also know that the 95`s had the R-134a compressors on them.
Te Question is if any ather year compressors will fit my car and if acura compressors will?????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ????
ths
ths
the b series ac compressor will fit on your swap only if you are using the ac bracket that come with the swap. but you have to change the ac hose because on your car will not fit into the b series ac compressor. why don't you buy a r12 to r134 conversion kit that sell at autozone or napa. if you do it right it will be fine and less work!!!
wow 91 degrees that all??? we were at like like 100+ w/ the heat index 2 weeks ago.. i rode the motorocycle for that whole week!!
e46joe
Sep 25, 2011 06:09 AM
