Are all LSD's interchangable?
Old Sep 4, 2003 | 01:37 PM
sirminder's Avatar
Default Are all LSD's interchangable?
In other words, would an ITR LSD fit the B16 hydro tranny? I know a CTR LSD would fit a B16 hydro tranny since they all have the same final drive 4.40
Old Sep 5, 2003 | 07:29 AM
PupaScoopa's Avatar
Default Re: Are all LSD's interchangable? (sirminder)
Yes it will, that's what I run. If you find an ITR LSD with a higher FD, you can always swap the gear.
Old Sep 5, 2003 | 09:19 AM
owen_the_soyboy's Avatar
there are issues with fitting a ITR lsd into a b16 tranny... it might be the final drive ring gear or something not clearing the laarge b18 lsd housing...
Old Sep 5, 2003 | 10:29 AM
sirminder's Avatar
Default Re: Are all LSD's interchangable? (owen_the_soyboy)
So I if I want to use the ITR LSD on the B16 Tranny and keep the Final Drive I currently have, I will have to change the Ring Gear to make the ITR LSD fit. But which Ring Gear would I use?
Old Sep 5, 2003 | 10:32 AM
mmuller's Avatar
Mad Scientist
itr lsd= gsr or itr final drive.
b18b or b16 final drive wont fit the itr lsd, the ring gear needs to be bigger
Old Sep 5, 2003 | 10:42 AM
sirminder's Avatar
Default Re: Are all LSD's interchangable? (mmuller)
But according to this site, the CTR, ITR and SiR2 have the same Final Drive
http://asian_e.tripod.com/Honda_Engine_Specs.htm
Or is that info incorrect?
Old Sep 5, 2003 | 11:02 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirminder &raquo;</TD></TR><TR><TD CLASS="quote">So I if I want to use the ITR LSD on the B16 Tranny and keep the Final Drive I currently have, I will have to change the Ring Gear to make the ITR LSD fit. But which Ring Gear would I use?</TD></TR></TABLE>
It will fit, but there are rules.
It mostly depends on which B16A hydro tranny you own.
If you own a 92-95 US or JDM Y21/S21 B16A tranny, a type-R LSD will not simply drop in, unless you use the final drive ring gear (4.40fd) that aides the ITR LSD. Or you can run any S80 (GSR) fd ring gear + the ITR LSD in order to make it work in a Y21/S21 tranny. Reason why -- the ITR LSD is bigger in size (diameter) than a Y21's LSD or stock differential + fd ring gear.
If you own a 96+ S4C B16 tranny (US Si coupe/JDM 96+ SiR/& CTR), an integra or civic Type-R LSD will simply drop in + fit the S4C's FD ring gear; Honda *upgraded* the Y21 B16A tranny to an S4C tranny, which is basically a rebadged S80 tranny.
Old Sep 5, 2003 | 11:13 AM
sirminder's Avatar
Default Re: Are all LSD's interchangable? (Katman)
Thanx for that info Katman. Im not too sure what exact tranny I got. When I bought my JDM 2nd Gen B16A, the tranny didnt come with a label. So Ill have to just say its the stock tranny. I get so confused when it comes to tranny codes.
Old Sep 5, 2003 | 11:19 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirminder &raquo;</TD></TR><TR><TD CLASS="quote">Thanx for that info Katman. Im not too sure what exact tranny I got. When I bought my JDM 2nd Gen B16A, the tranny didnt come with a label. So Ill have to just say its the stock tranny. I get so confused when it comes to tranny codes.</TD></TR></TABLE>
Ok. I'm assuming its a Y21 B16 tranny since all US or JDM 92-95 B16A engines come with Y21 tranny's. But then again, some places do weird things like swap tranny's, so I can't be too sure of what tranny your engine actually has, but I'm guesssing a Y21..
Old Sep 5, 2003 | 11:21 AM
sirminder's Avatar
Besides the label that could be easily taken off, would there be any other markings to determine what tranny I got?
Old Sep 5, 2003 | 11:31 AM
mmuller's Avatar
Mad Scientist
if it is a sc4, it should have the vin tag on it
Old Sep 5, 2003 | 11:34 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirminder &raquo;</TD></TR><TR><TD CLASS="quote">Besides the label that could be easily taken off, would there be any other markings to determine what tranny I got?</TD></TR></TABLE>
not that I know of, unless you crack the tranny open and count the teeth on the fd ring. That will tell you if you have a 4.40 tranny or not.
harta_tec
Jun 20, 2008 11:17 AM
ej1252
Mar 29, 2008 06:13 PM
SupaFly_Honda
May 12, 2004 05:12 AM
EG-cellent
Jul 12, 2003 04:28 PM
