VTEC not working
Old Sep 4, 2003 | 12:59 PM
Cm91h22a's Avatar
Default VTEC not working
94 gsr w/ web cams crower springs&retainers. Car worked fine for about a month then vtec stopped working. Already checked wiring, solinoid, cam timing, vtec oil press. sensor,changed ecu. Vtec enguages when a 12v source is wired direct.
Any help on this PROBLEM is greatly appreciated!
Old Sep 8, 2003 | 09:19 AM
92h22a's Avatar
Default Re: VTEC not working (Cm91h22a)
Bump
Old Sep 8, 2003 | 10:45 AM
AllmotorJunkie's Avatar
first off...any CEL?
secondly, have you tried searching because over the past month...i have seen many threads "HELP>> my vtec doesn't work!!!"
Maybe you can find the answer from previous threads.....
Old Sep 8, 2003 | 11:08 AM
TeStUdO's Avatar
maybe a bad ground on the pressure switch??
Old Sep 8, 2003 | 02:35 PM
jcda6's Avatar
Oil level adequate? VSS plugged in? Bad ground? Solenoid screen clean? Those are some of the area that is worth investigating.
-Jeff C.
Old Sep 8, 2003 | 04:21 PM
Forrest Gump 9's Avatar
Default Re: VTEC not working (jcda6)
Check the oil pressure sensor. That's what happen to mine last time Vtec not working. Hope this will help.
Old Sep 8, 2003 | 06:45 PM
Renegade's Avatar
Default Re: VTEC not working (PaintStripper)
I've had VTEC not kick in when the oil was low. not enough oil the pressure cannot get high enought ot activate, well that is my theory at least. Check your oil..
Old Sep 8, 2003 | 06:47 PM
TeStUdO's Avatar
Well he said it engages when a 12v is directly put to it, so im thinking its a faulty wire somewhere
Old Sep 9, 2003 | 06:59 PM
Cm91h22a's Avatar
Default Re: (TeStUdO)
So i was driving the car yesterday and the ignitor went out,I replaced it and now vtec works fine. I would imagine that it had something to do with the RPM signal from the distributor to the ecu Thanks for the help.
clyde
94wip
12
Jun 20, 2024 07:23 PM
tigasin
Nov 14, 2008 11:58 PM
karkrazy9
Jun 29, 2008 07:35 PM
mister2racer
Jun 26, 2005 07:13 PM
abolish415
Jun 13, 2005 10:48 AM
