290cc prelude injectors on ls/vtec too much?
Old Sep 4, 2003 | 11:58 AM
skribblah's Avatar
Default 290cc prelude injectors on ls/vtec too much?
type r pistons
p&p'd b16 head
stock b16 IM for now...
chipped p28 to break in, i want to get a hondata.
think 290cc is just right / too much / not enough?
Old Sep 4, 2003 | 01:03 PM
Casey's Avatar
Default Re: 290cc prelude injectors on ls/vtec too much? (skribblah)
should be ok, could go bigger though
Old Sep 4, 2003 | 01:14 PM
Austin's Avatar
Default Re: 290cc prelude injectors on ls/vtec too much? (Casey)
I'd look into some 310's or larger...I'm running 290's, and coming close to running at the max of the duty cycle.
Austin
Old Sep 4, 2003 | 04:48 PM
teg92's Avatar
I don't have much experience with that particular setup but hondata romeditor computes that 300cc injectors would be the perfect replacement for a B20VTEC setup with stock cams and compression. With the higher compression and lesser displacement I would have to say that 290cc should be perfect.
Old Sep 4, 2003 | 05:29 PM
skribblah's Avatar
Default Re: 290cc prelude injectors on ls/vtec too much? (teg92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg92 &raquo;</TD></TR><TR><TD CLASS="quote">I don't have much experience with that particular setup but hondata romeditor computes that 300cc injectors would be the perfect replacement for a B20VTEC setup with stock cams and compression. With the higher compression and lesser displacement I would have to say that 290cc should be perfect.</TD></TR></TABLE>
thats what im thinking, my compression would be around 11:1 with the block decked and the head slightly milled, and i plan on running a GSR exhaust cam with a CTR intake cam.
Old Sep 4, 2003 | 09:29 PM
MEANB18's Avatar
yeah it should be fine, but I'd go bigger... 310's
Old Sep 5, 2003 | 09:18 AM
Jeff C's Avatar
Default Re: 290cc prelude injectors on ls/vtec too much? (MEANB18)
Why would a lsvtec need bigger than 240cc? ITR's run 240's and a lsvtec is not too much more power than that.
Old Sep 5, 2003 | 10:17 AM
Austin's Avatar
Default Re: 290cc prelude injectors on ls/vtec too much? (Jeff C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff C &raquo;</TD></TR><TR><TD CLASS="quote">Why would a lsvtec need bigger than 240cc? ITR's run 240's and a lsvtec is not too much more power than that.</TD></TR></TABLE>
I have an ITR, running 290cc/min, running 11:1 compression...I have the injectors at over 80% duty cycle on stock cams...I'm of the opinion that unless you're going to raise the fuel pressure you will need to run injectors larger than 290cc/min.
Austin
Old Sep 5, 2003 | 10:36 AM
Jeff C's Avatar
Default Re: 290cc prelude injectors on ls/vtec too much? (Austin)
What fuel pressure do you have your ITR at?
So then would you say that one could raise the fuel press to say 50psi and use 240cc injectors?
Old Sep 5, 2003 | 10:57 AM
Austin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff C &raquo;</TD></TR><TR><TD CLASS="quote">What fuel pressure do you have your ITR at?
So then would you say that one could raise the fuel press to say 50psi and use 240cc injectors?</TD></TR></TABLE>
Stock ITR fuel pressure is 47-53psi, hose off. That's how they use the 240's on all of the B series engines, they change the fuel pressure as needed and change the injector duration in the ecu. I'm saying that you would need 60-70 psi to run the 290's...but with higher fuel pressures come additional issues...
Austin
Old Sep 5, 2003 | 06:27 PM
b19coupe's Avatar
290cc is the bare minimum IMO. If you are going to get Hondata, go with 370cc's. It's a lot easier to tune out fuel (with big injectors) than to add it if you have smaller injectors.
Old Sep 5, 2003 | 07:38 PM
skribblah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">
Austin</TD></TR></TABLE>
enlighten me...
Old Sep 5, 2003 | 08:49 PM
T4eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MEANB18 &raquo;</TD></TR><TR><TD CLASS="quote">yeah it should be fine, but I'd go bigger... 310's
310's
Old Sep 6, 2003 | 06:21 AM
B16C's Avatar
i think 290cc's are fine. it shocks me when i see so many people running huge injectors on thier motors. many people run 200whp with 310's with fuel to spare. the only time i've seen these b series motors need excessive fuel is when these expensive race headers are used. i don't know, maybe its me, but 290's should be fine. holla
Old Sep 6, 2003 | 06:35 AM
SirStovetop's Avatar
Default Re: (B16C)
i am running the h22 290cc injectors in my ls/vtec. it runs fine with 290, you should not need anyting bigger than that.
Old Sep 6, 2003 | 07:34 AM
AussieK24's Avatar
With those mods 290 will be fine BUT you will mod for more power later so why replace injectors twice. I just got 350cc ones as I was maxing the 240's. I have standalone and so should you hehe
Old Sep 6, 2003 | 09:50 AM
Triple T's Avatar
Default Re: 290cc prelude injectors on ls/vtec too much? (AussieB20vtec)
Im running 290cc prelude injectors on my ls/vtec. b16 head, jdm r pistons, ctr cams, AEBS intake mani. I think it should be fine but well see when i hit the dyno.
Lordofdark176
Nov 21, 2007 08:42 PM
RACING INTEGRATION
Nov 29, 2004 08:10 AM
GapxGuy
16
Apr 21, 2004 11:33 AM
ELESVEE
Jun 21, 2003 06:37 PM
BlackGSR
Jun 19, 2002 10:22 AM
