car revs without pressing gas
Old Sep 3, 2003 | 07:46 PM
wanttorace's Avatar
Default car revs without pressing gas
i just put a odb0 ls motor into a odb1 integra when i start the car it just starts to rev even without the throttle cable on and its throwing no codes could the odb0 intake manifold caz this im puzzled any suggestions would be appreciated
Old Sep 3, 2003 | 07:52 PM
VTECorona's Avatar
Default Re: car revs without pressing gas (jjd493925)
Is the throttle body stuck open or anything? Vacuum leaks?
Old Sep 3, 2003 | 10:18 PM
Kamin's Avatar
you have a vacuum leak somewhere
Old Sep 3, 2003 | 11:46 PM
.xcalibur.'s Avatar
my car does that too ever since i went to OBD1
Old Sep 4, 2003 | 02:45 AM
wanttorace's Avatar
Default Re: car revs without pressing gas (.xcalibur.)
like i staRT it and it slowly revs up to like 5 and keepps going so i shut it off
Old Sep 4, 2003 | 03:14 PM
wanttorace's Avatar
changed intake manifold to odb1 and it works fine now whats the difference and what would cause for the odb0 one to rev the **** out the motor without the gas being pressed
Old Sep 4, 2003 | 03:33 PM
mmuller's Avatar
Mad Scientist
you prolly had a leak in the intake man.
Old Sep 4, 2003 | 03:37 PM
3gdude's Avatar
This sounds easy. If the motor revs past 1500rpm with your foot off the gas, without going into "fuel cut" mode (about 1500 rpm), than the TPS voltage was not sending a "closed throttle" voltage to the ECU.....Swapping the throttle bodies or adjusting the TPS with the hard stop screw to the correct "closed throttle" setting, probably will fix this..... 3gdude
Old Sep 4, 2003 | 04:05 PM
MEANB18's Avatar
Default Re: car revs without pressing gas (3gdude)
if it's still going up and up and up real quick like, you definately have a stuck throttle
Old Sep 4, 2003 | 04:07 PM
wanttorace's Avatar
Default Re: car revs without pressing gas (MEANB18)
with the odb 0 it would just rev up to fuel cut off at 7200 and now it idles fine
Old Sep 5, 2003 | 02:16 AM
mattb16a1civic's Avatar
you let it free rev up to 7200 and even on a cold engine. thats just wrong. im not gonna say anymore other than i feel your engines pain, ouch.
Old Sep 5, 2003 | 07:37 AM
wanttorace's Avatar
Default Re: (mattb16a1civic)
you r dumb if you would have read the post when i started it the car started reving i though it would cut off at like 2 grand caz the timing and the screw on the trttle body were adjusted so i would go up high and reved really fast to fuel cut off no **** its not good for a motor to do that ill go back in time and not start my car and change the manifold for you
Old Sep 5, 2003 | 12:12 PM
actually i did read the thread and i understand at first it would cut off on its own at "like 2 grand" but you should just let it do that, at least have someone in the car just in case. I hope everything works out for you and that you dont have any further problems. I wasnt trying to flame you and I apologize if it came across that way.
Old Sep 5, 2003 | 12:27 PM
turbochic's Avatar
Default Re: car revs without pressing gas (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you prolly had a leak in the intake man.</TD></TR></TABLE>
had the same exact problem. i sprayed some carb cleaner around the areas that could possibly have a vacuum leak, found it in the intake mani.
took it off found some residue of the old gasket on there that didnt come off, scrapped it pout the i.m back on, no more high revving.
good luck tho
Old Sep 7, 2003 | 07:04 PM
wanttorace's Avatar
Default Re: car revs without pressing gas (fmaxturbochic)
there is a spot for a sensor under the throttle body and it was leaking air out
Old Sep 7, 2003 | 07:38 PM
davken1102's Avatar
i would check your TPS , it sounds like you have a problem there..
smeags
10
Jul 20, 2013 10:22 AM
F20B_accord
Feb 19, 2011 07:26 AM
knaira112387
Honda Civic (2006 - 2015)
30
Nov 13, 2008 10:14 AM
1337 Si
May 24, 2003 01:36 AM
1337 Si
May 23, 2003 08:32 PM
