turbo ??
Old Sep 3, 2003 | 07:05 PM
viet4gvtec's Avatar
Default turbo ??
just done install my custom turbo for my 93vtec lude today, went for a test drive, turbo spool up fast . i went pass 8000rpm ,check engine light came on, car stall out . i turned off i engine and turned it back on everything was nomal. what happed
my lude
93vtec stock bottom, garret t3/4 turbo,fmu, only 6 psi
Old Sep 3, 2003 | 07:45 PM
DubbleD's Avatar
Default Re: turbo ?? (viet4gvtec)
misfire?
Old Sep 3, 2003 | 08:56 PM
machinehead's Avatar
break in period?
Old Sep 4, 2003 | 07:46 AM
Mikeyslude's Avatar
Default Re: (machinehead)
axe the fmu and get some kind of Engine Management.
Old Sep 4, 2003 | 08:56 AM
prelittlelude's Avatar
how the hell did you go past 8k on a 93 , my guess was that you lost fuel or it got so messed up that it casued you car just to die. i know 4thgens have a fuel cut at 7400, so if some how you took i to 8k and then you ecu fuel cut but the fmu was still trying to keep fuel at a high presure it could have caused something to go wrong.
why 8k?
Old Sep 4, 2003 | 01:34 PM
PrecisionH23a's Avatar
A regular turbo kit does not require a break in period, and those are words directly from the big dogs out at Drag.
As far as your CEL light, it could be either running lean, misfire, something to do with vacuum lines, loose connection of a sensor(s), or about 10 other things.
I guess the CEL went away after you restart the car and has not come on since, correct?
Old Sep 4, 2003 | 07:29 PM
viet4gvtec's Avatar
Default Re: (GudeH23a)
check engine light came back on when you got in high rpm. my mechanic said it's the map sensor and something to do with the missing link. sound right???
lloydadvance
Oct 23, 2005 12:51 PM
civproject14
Jan 14, 2005 06:59 AM
wshondaman
Dec 1, 2004 09:49 PM
shadowdawn
Mar 30, 2002 08:43 PM
