Installing a camber kit, didn't come with instructions..
Yeah, we need more info. Just so you know, there's more than 1 kind of camber kit out there, and there's different ways to install them.. Give a pic. That will be more helpfull.
bump, doing this today - let's help me out
I FOUND INSTRUCTIONS ONLINE
Step 1: Raise vehicle off the ground and place the jack stands on the four jacking points.
Step 2: Open the engine compartment.
Step 3: You'll notice that there are 2 large locking nuts holding the upper control arm to the strut tower. Remove these two nuts and turn the control arm around using the tire as a working space.
Step 4: Remove the anchor bolts from the control arm. Install the new adjustable anchors with the large radius facing the ball joint.
Step 5: Reinstall the control arm to the strut tower and torque locking nuts to manufacturer specs.
What are the specs for this? I dont have a manual
Step 6: Adjust camber to desired specification by sliding the control arm 1-1/4 to 3 degrees positive. Tighten and torque the bottom adjusted nut to 35 lbs.
torque to specs=tight
I think it is around 60 lb-ft but I dont have my manual on me.
https://honda-tech.com/zerothread?id=606668
There is a link to more detailed instructions.
-Dustin
-Dustin
thanks just got it done, not near as bad as I thought
now I got fender rub, for some reason the camber kit dropped me more (NO WHEEL GAP)
Steve90HB
Sep 4, 2003 05:08 PM
