?? for camber kit install
Old Feb 1, 2002 | 12:32 PM
96whitels's Avatar
New User
Default ?? for camber kit install
i was wondering to remove the upper control arm for the camber kit what do i need to take off? Im just figuring that i have to loosen the two top bolts that holds the arm and the ball joint. Do i need to remove the strut too?
Old Feb 1, 2002 | 12:40 PM
ingrate's Avatar
25 Year Member
Default Re: ?? for camber kit install (96whitels)
maybe you could maneuver the UCA around the strut assembly, but it'll make the job much easier if you just took it out. then just take off the 2 nuts from the engine bay and it'll swing out.
Old Feb 1, 2002 | 07:12 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ?? for camber kit install (In7egrity)
Just raise the car, unbolt the 2 upper control arm bolts, and then you can swing the control arm around to install the camber it. The steering knuckle will swing out/down some so you can get it around the shock/spring.
Steve90HB
Sep 4, 2003 12:47 PM
Thrillhouse
Aug 9, 2003 01:53 PM
toooslow
May 28, 2003 02:50 PM
1bar
Aug 21, 2002 04:06 PM
Fooser
Mar 28, 2002 07:59 AM
