Not Sure if vtec is works any help?
Old Sep 3, 2003 | 03:35 PM
ramz7887's Avatar
Default Not Sure if vtec is works any help?
I took my car a couple of days ago to get my timing belt replaced and it turns out that the guy who put the belt on last time put it on wrong The guys at the shop said the timing was way off and it caused the car to fire on the wrong cyclinders!!! They also told me to get a vavle adjustment because the timing has been off for so long. Well anywas when they took the valve cover off the oil was caked on all over. Its looked terrible. The guy said that it was the worst build up he had ever seen on a honda. After the job was done the guy told me that he took it for a test drive and said that he couldn't hear the vtect kick in. Its a sohc d16 so i know the kickin won't be that noticable like on the b series but what do you guys think? Do you think that the oil build up could have clogged up the vtec solinoide? Please let me know.
Old Sep 3, 2003 | 04:19 PM
tangb2023
Guest
Posts: n/a
Default Re: Not Sure if vtec is works any help? (ramz7887)
take the solonoid off and clean it and see. clean the screen. and use seafoam or something to get all the build up off. why was the *** at the shop taking ur car up to vtec any way?
Old Sep 3, 2003 | 06:34 PM
ramz7887's Avatar
where is the vtec solonoid?
Old Sep 3, 2003 | 06:41 PM
DaveSi677's Avatar
its behind the engine block on the left. You see a little cylinder looking object and that is the Vtec soleinoid. Ill try to get a pick.
Old Sep 3, 2003 | 06:48 PM
2000blackgsr's Avatar
Default Re: Not Sure if vtec is works any help? (93SiVtec677)
Its on the left side of the head right by the distributor.
There is an upclose pic in this thread, but its the best I can do.
https://honda-tech.com/zerothread?id=457557
Old Sep 3, 2003 | 06:57 PM
ek9mugen's Avatar
Default Re: Not Sure if vtec is works any help? (96coupe)
so your timing belt is on right again?
if so get a valve adjustment, make sure the timing is set to stock and get an oil change. then take further actions if needed
Old Sep 3, 2003 | 07:02 PM
ramz7887's Avatar
Default Re: Not Sure if vtec is works any help? (ek9mugen)
yea the timing is good i'm getting a valve adjustment tomarrow and i already had the oil changed a couple of days ago.
Old Sep 3, 2003 | 08:04 PM
DevLishPlaya's Avatar
is it easy to clean the vtec selenoid? and how?
ugen
Apr 24, 2015 09:01 PM
hondaaccordf23
Aug 13, 2012 07:14 AM
teh Dirka
Nov 19, 2008 08:35 PM
lsvtec2000
Dec 30, 2007 10:21 PM
crazy_pedestrian
Aug 5, 2006 06:08 AM
