Injectors
Old Sep 3, 2003 | 01:27 PM
abeaujuin's Avatar
Default Injectors
I removed my injectors to get to the egr ports. I removed 2 injectors completly off of the rail. Now my car is leaking gas from those two. Is there a seal that needs to be replace everytime you remove the injectors?
Old Sep 3, 2003 | 03:32 PM
StimpyBoy's Avatar
Default Re: Injectors (abeaujuin)
I didn't have to. Did you reseat them nice and snug, and torque down the fuel rail to proper spec?
Old Sep 3, 2003 | 06:45 PM
AngryTroll's Avatar
Normally, you don't need to.
Old Sep 3, 2003 | 07:33 PM
MAX HARDCORE's Avatar
Default Re: Injectors (AngryTroll)
well... if there is a tear in the o ring thats your problem.
Old Sep 4, 2003 | 06:31 AM
abeaujuin's Avatar
Default Re: Injectors (MAX HARDCORE)
Yes there was a tear in the o-rings. I went everywhere to try and find the o-rings no one has them in stock. Where can I get them from?
Old Sep 4, 2003 | 06:32 AM
abeaujuin's Avatar
Default Re: Injectors (StimpyBoy)
I did, but I think while I was forcing the injectors into the rail, I riped the o-ring.
Old Sep 4, 2003 | 07:26 AM
Hondaaccordvtec's Avatar
try this place, i think what you need is part #30
http://www.hondaautomotivepart...IFOLD
Old Sep 4, 2003 | 07:44 AM
btlfed1's Avatar
Default Re: Injectors (Hondaaccordvtec)
your dealer should be able to get them and if not try a company that actually makes fuel rails and see if you can buy them. Next time you put them in put some oil on them and on the inside of the hole on the rail and they should slide right in.
Old Sep 4, 2003 | 07:49 AM
abeaujuin's Avatar
Default Re: Injectors (btlfed1)
The Dealer wants $1.97 per top ring and $7.97 per bottom ring. That's crazy. I need to get them cheaper then that locally.
Old Sep 4, 2003 | 08:05 AM
GimpyAccord's Avatar
Last time I needed orings I got injector reseal kits from Napa.. it was like 3 bucks per injector!
SolAssassin
Nov 23, 2009 03:20 PM
tbuck23
Apr 24, 2007 01:12 PM
jarven93
Jan 12, 2007 10:20 AM
SiRay13
Oct 21, 2006 04:30 PM
