engine swap headaches need help
Old Sep 3, 2003 | 11:56 AM
coolusername's Avatar
Default engine swap headaches need help
okay to start out I bought a 93 d15z1 vtec engine out of a canadian vx civic for my 89 civic sedan that originally had a d15b2. i used my old intake, exhaust, distributor, tranny, ac, ps, and alt. I have the motor in my car, with my parts hooked up but when i try to start the motor it just turns over. i have check the firing order and made sure the wires are in the right cylinder. i have also checked to make sure the spark plugs are getting spark which they are. I am lost as to why the engine wont start. it seems like the injectors are not delivering and fuel. when i pull the plugs out they are bone dry. I can only think that i did not wiring something right. Does anyone know when i can get ahold of a wiring diagram or something to help.
Thanks
Old Sep 3, 2003 | 12:01 PM
Default Re: engine swap headaches need help (blue89civic)
also there is a sensor on the top side of the intake right behind the throttle body. it had a plug on the bottom and 2 vaccum line on top. when i removed the old engine the 2 vaccum lines got broke off. could that be causing problems, if so what is the name of that piece. i have yet to find out what it is called. thanks!
Old Sep 3, 2003 | 12:19 PM
anyone?
Old Sep 4, 2003 | 10:05 AM
bump?
Old Sep 4, 2003 | 10:27 AM
zccrx's Avatar
WELL IM NO VTEC GUY BUT I KNOW THAT IF YOUR NOT USING THE RIGHT ECU IT WONT WORK ALSO CAN U HEAR YOUR FEUL PIUMP TURNING ON IF NOT CHECK IT,ARE U GETTING ANY CODES CHECK THEM WITH THE BOOK.YOUR RELAY COULD NOT WORK ALSO BUT THERE ARE TOO MANY THING I CAN JUST NAME OUT CHECK THE CODES POST THEM AND TAKE IT FROM THERE. WHEN MY FUEL WASNT GOING IN IT WAS BECAUSE I HAD A BAD GROUND. CHECK THE GROUND BEHIND THE MOTOR BY THE (WATER THERMOSTAT) I THINK THATS RIGHT ANY WAYS THE ONE THAT POKES OUT OF YOUR HARNESS AND IS CONNECTED BEHIND THERE SOME WHERE
Old Sep 4, 2003 | 10:32 AM
Default Re: engine swap headaches need help (zccrx)
okay, there was one wire with two eyes on it that we didnt bolt down. couldnt find a spot for it. that might be causing a problem. ill check it out and see what happens. thanks
Old Sep 4, 2003 | 10:34 AM
YumVTEC's Avatar
umm, did you use the MPFI intake manifold from the d15z or did you use your stock DPFI d15b intake manifold? If you're using the MPFI manifold then you should've converted your wiring to MPFI. Also, what ECU are you using to run this thing?
Old Sep 4, 2003 | 10:39 AM
Default Re: engine swap headaches need help (YumVTEC)
i am using my dpfi manifold and stock ecu
Old Sep 4, 2003 | 12:15 PM
YumVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue89civic &raquo;</TD></TR><TR><TD CLASS="quote">i am using my dpfi manifold and stock ecu</TD></TR></TABLE>
it should work just fine to tell you the truth. I would check your fuses to see if you popped one somewhere, and also check your grounds to make sure they are hooked up okay.
if you're interested i have an MPFI setup from a 91 CRX Si that I am selling (ECU, distributor, intake manifold, throttle body, fuel rail, injectors, resistor box, sensors, etc.)
Old Sep 4, 2003 | 01:58 PM
okay thanks. i am interested in a mpfi swap. how much are you asking? also what kind of wiring is involved? i am not good with stuff like that, thats why i am having some many problems. thanks
Old Sep 4, 2003 | 04:46 PM
moysaystor's Avatar
The problem sounds like you have the distributor 180 degress off. Check the distributor to make sure that it is sitting flush with the head. If not take it off and turn that dam wedge looking that goes in the cam !over! place the dist. back on and see what happens. If that don't do it pull off you injector resistor plug and look for any bent pins. Or you might of replaced the wrong bolt that goes into the gas filter. The banjo bolt is what goes in the fuel filter it has a hole in it for gas to go threw to the fuel rail.
Old Sep 4, 2003 | 05:16 PM
bluecrxsi's Avatar
Default Re: engine swap headaches need help (moysaystor)
plus make sure your grounds are right or she'll never start
Old Sep 5, 2003 | 08:08 AM
Default Re: engine swap headaches need help (bluecrxsi)
okay thanks guys. found out that it was a ground problem.
now i have a new problem. the engine starts but will not hold idle. if i take the #1 cylinder spark plug out it will hold idle and run. if i try to replace the plug it kills the engine. i am thinking there is a problem with the head but i dont know what could be causing the problem. if anyone know it would hep.
thanks
Old Sep 5, 2003 | 11:28 AM
civickiller's Avatar
is the spark plug hitting hte piston ?
Old Sep 5, 2003 | 11:38 AM
Default Re: engine swap headaches need help (civickiller)
i dont know for sure. cant see in the head
Old Sep 5, 2003 | 11:52 AM
did u make sure the timing was right ? look at the spark plug, if the little arm opposte the electrode is smashed against the electrode then u probably got the piston hitting the spark plug
its weird that it dies because a car should still be able to run on 3 cylinders without dying.
Old Sep 5, 2003 | 11:55 AM
the spark plug has not been hit. the car doesnt die when the spark plug is out. it dies when the spark plug is in.
Old Sep 5, 2003 | 01:44 PM
91civicEX's Avatar
firing order i think. check it with a timing light.
Old Sep 5, 2003 | 03:17 PM
YumVTEC's Avatar
Default Re: (91civicLX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">firing order i think. check it with a timing light.</TD></TR></TABLE>
definitely firing order. change the order of your spark plug wires. also, if you want my MPFI you can have it for $200 shipped. it's going on Ebay this weekend if no one buys it here.
Old Sep 5, 2003 | 03:31 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (YumVTEC)
D15/16 firing order:
If pic does not work click
here*
Old Sep 9, 2003 | 05:34 AM
Default Re: (88DXCRX)
i am using my d15b2 distributor with the d15z1 head. i have had the plugs in the right firing order but it does not work.
Dreams86
Aug 15, 2016 12:44 AM
Gunner142
Jan 22, 2009 11:49 AM
2gen_tegs_rule
Sep 2, 2006 09:05 AM
roxy2000
11
Aug 16, 2005 12:34 PM
biggmike2
Jan 21, 2004 10:56 PM
