all motor b17 bottom end
Old Sep 3, 2003 | 07:35 AM
milanoGSR's Avatar
Default all motor b17 bottom end
Just curious as what bottom end you b17/b16 guys used. I wanted to do CTR, but I'm going to have to get custom rods, so what rods will work with CTR pistons in a b17 block? I'm going to use skunk2 stage 1's up top.
Old Sep 3, 2003 | 08:16 AM
VTEC-DA's Avatar
Default Re: all motor b17 bottom end (milanoGSR)
Why do you think you need custom rods for CTR pistons in a b17?
Old Sep 10, 2003 | 04:58 AM
97itr86's Avatar
Default Re: all motor b17 bottom end (VTEC-DA)
Doesn't eagle make rods for the B17? I was wondering if anyone has done an all motor setup with the b17. What kind of numbers did you get out of it?
Old Sep 10, 2003 | 05:25 AM
VTEC-DA's Avatar
Default Re: all motor b17 bottom end (97itr86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97itr86 &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't eagle make rods for the B17? I was wondering if anyone has done an all motor setup with the b17. What kind of numbers did you get out of it?</TD></TR></TABLE>
Not sure about Eagle. I know for a while, Crower made the only rods available for the b17. I dont know if Eagle has come out with any since then.
Old Sep 10, 2003 | 07:26 AM
92redgsr's Avatar
you can use you stock rods with ctr pistions. Im gettin ready to do it you just have to shave your stock rods. From what I have heard its only 1mm off each side or 1mm total.
Old Sep 10, 2003 | 07:32 AM
lsvtecracer's Avatar
Default Re: all motor b17 bottom end (92redgsr)
There was a local guy down here that dyno 165 whp and I think 110-115 lbs of torque with an all motor b17a setup. I'm not sure what he did to it.
Old Sep 11, 2003 | 07:58 AM
97itr86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redgsr &raquo;</TD></TR><TR><TD CLASS="quote">you can use you stock rods with ctr pistions. Im gettin ready to do it you just have to shave your stock rods. From what I have heard its only 1mm off each side or 1mm total.</TD></TR></TABLE>
I heard the the stock rods suck ***.
Old Sep 11, 2003 | 10:19 AM
BluePrintmfg.com's Avatar
Banned
LS/VTEC stock rods, ITR pistons 12.6 had the motor with no problems for 2years! I think its what you build the motor for and how you build the motor!
I heard the the stock rods suck ***.</TD></TR></TABLE>
Old Sep 11, 2003 | 12:26 PM
97itr86's Avatar
Default Re: all motor b17 bottom end (11sec.ALL MOTOR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11sec.ALL MOTOR &raquo;</TD></TR><TR><TD CLASS="quote">LS/VTEC stock rods, ITR pistons 12.6 had the motor with no problems for 2years! I think its what you build the motor for and how you build the motor!
No I am saying I have heard the B17 rods are weak and flemsy. I hope to find some eagles or crowers for it soon.What do you mean LS/VTEC stock rods? Do you mean use stock LS rods.
GEN2 LS
Aug 21, 2009 01:44 PM
ITRiWISH
Mar 10, 2008 08:12 PM
MrMike
Sep 21, 2003 09:28 PM
Spids5
May 24, 2003 04:20 PM
b17gsr
Feb 21, 2002 10:11 AM
