DAmnit, I have this prob with my LS swap in my hatch.
Old Aug 17, 2001 | 02:54 PM
synergy004's Avatar
Default DAmnit, I have this prob with my LS swap in my hatch.
We did the swap in my car, We put a custom turbo set up in there. Everything looks dandy. When we went for a test drive. The damn car had no power whatsover. Id push the gas pedal and still no power. Feels like I have no compression.. I checked the ecu and it was showing a code 7 with my TPS. IS this because I have a crappy one.. I was told it could be my spark plug wires, then I was told my valves are too tight. I am gonna trouble shoot it but wanted some other advice as to if these are solutions or has anyone had this problem.
thanks here is my setup
1992 civic hatchback VX
1992 LS motor
60-1 Turbo
PP head, port matched intake manifold, bored and butterflied throttle body
Custom tubular manifold
Web dual valve springs
FErrea SS valves
Web titanium retainers
Eagle rods
JE 9.0:1 pistons
Sleeved block
Greddy BOV
GReddy TT
TIAL Wastegate
MSD 6AL ignition
GSR tranny
KAAZ LSD
BLITZ Boost Controller
Stock ECU for now (SPEEDPRO on the way)
Oversized INtercooler
BLAH BLAH BLAH and other stuff
Old Aug 17, 2001 | 02:58 PM
fixhondas's Avatar
Default Re: DAmnit, I have this prob with my LS swap in my hatch. (synergy004)
do you have your IAC and TPS connectors switched? They will fit each other.
Old Aug 17, 2001 | 03:02 PM
synergy004's Avatar
Default Re: DAmnit, I have this prob with my LS swap in my hatch. (fixhondas)
it also wants to keep reving high.
I will go and check that now
Old Aug 17, 2001 | 03:05 PM
synergy004's Avatar
I just checked it, do you mean the MAP SENSOR AND THE TPS. well I have everything connected right.. I checked all wiring diagrams, everything checks out
fixhondas's Avatar
Whoops- not the tps- the IAC and IAT are switchable- I meant the TPS and MAP. How does the idle act? What exactly happens when you gas it?
[Modified by fixhondas, 12:08 AM 8/18/2001]
Old Aug 17, 2001 | 03:10 PM
synergy004's Avatar
man when I step on it, it acts waco, when I rev it, the RPM guage jumps all over.
Old Aug 17, 2001 | 03:13 PM
fixhondas's Avatar
which distributor are you using?
Old Aug 17, 2001 | 03:20 PM
92CivicSiR's Avatar
New User
you know, that setup sound like it will scream, let me know how it turns out.
Old Aug 17, 2001 | 03:37 PM
synergy004's Avatar
Default Re: DAmnit, I have this prob with my LS swap in my hatch. (92CivicSiR)
yeah I will post the times and pics soon, but the distributor is off that motor originally, I had it checked
syosaekha
May 30, 2009 03:43 PM
SC61HB
Oct 7, 2007 03:40 AM
9K RDLNE
Oct 17, 2005 12:41 PM
b18b25psi
Mar 3, 2002 02:11 PM
