? About Proposed LS/VTEC Setup- HELP!
Old Sep 2, 2003 | 06:48 PM
Civic's Avatar
Default ? About Proposed LS/VTEC Setup- HELP!
okay, here's the deal. i am currently building an ls/vtec swap for my eg. i want to go with the jun type 3 cam's along with their line of valve springs and retainers. i will be using eagle h beam rods but want to know what is a safe compression piston to run with these cams? i am looking into custom pistons anywhere from the 12:1+ range. i don't want this to be an all out drag car, but barely streetable is fine. the head is not milled, port/polished etc. the block is standard bore as well. any info or tech writeups would be appreciated. thanks!
Old Sep 3, 2003 | 06:58 AM
skribblah's Avatar
Default Re: ? About Proposed LS/VTEC Setup- HELP! (Civic)
read the post in my signature for a lot of information on ls/vtec's. its a good read.
Old Sep 3, 2003 | 04:25 PM
Civic's Avatar
thanks, appreciate it.
carlossolorzano
Aug 31, 2011 08:25 PM
imissmyfc3s
11
May 22, 2005 06:10 PM
teg4life
Sep 21, 2004 09:17 AM
SpoonboyChoi
Feb 3, 2003 10:46 AM
