Did the 92-95 5th gen civic coupes come in an "SI" model?
Old Aug 17, 2001 | 12:43 PM
Kalokohan's Avatar
New User
Default Did the 92-95 5th gen civic coupes come in an "SI" model?
Just wondering, my friend just bought a hooked up 5th gen civic coupe and he says it's an "SI" model. I know the hatchbacks came in Si's but I'm not sure about the coupes.
Old Aug 17, 2001 | 01:25 PM
teq1816's Avatar
Default Re: Did the 92-95 5th gen civic coupes come in an "SI" model? (Guardson3r3)
Your friend is wrong. There were two coupe models, the dx and ex. The si was only available as a hatchback.
Old Aug 17, 2001 | 02:44 PM
92CivicSiR's Avatar
New User
Default Re: Did the 92-95 5th gen civic coupes come in an "SI" model? (teq1816)
teq1816 is absolutely correct. The coupe DID NOT come in a Si model. Only the HB. I hope that I would know, I have a 92 Si HB teeheehee
Old Aug 17, 2001 | 06:07 PM
RA34's Avatar
Once again, in Canada we had an Si model but I think in the US it was called the EX
Old Aug 17, 2001 | 06:09 PM
enthusiast128's Avatar
Default Re: Did the 92-95 5th gen civic coupes come in an "SI" model? (RA34)
RA34 is correct... Canada had the Si which in America is called EX
Old Aug 17, 2001 | 06:56 PM
Mike P.'s Avatar
25 Year Member
Default Re: Did the 92-95 5th gen civic coupes come in an "SI" model? (Hybrid Hatch 128)
Well, that there would make some sense.
Old Aug 17, 2001 | 07:01 PM
Minorgliche's Avatar
New User
what is the difference between the engines? they both have Vtec and both SOHC rite?
Old Aug 18, 2001 | 12:51 AM
abraunworth's Avatar
New User
Default Re: Did the 92-95 5th gen civic coupes come in an "SI" model? (Minorgliche)
I don't think there is a difference. They are both D16 Z6. Maybe they have different cams???
Old Aug 18, 2001 | 04:20 AM
92CivicSiR's Avatar
New User
Default Re: Did the 92-95 5th gen civic coupes come in an "SI" model? (abraunworth)
Yes, they are both the same enginge, but the Si is the "Sporty" model. The Si comes with things hat the EX does not, like rear disk brakes, stiffer suspension, sun roof, 5-speed, there is more stuff, I just can't remember it all.
Old Aug 18, 2001 | 06:16 AM
CRX_VTEC's Avatar
Default Re: Did the 92-95 5th gen civic coupes come in an "SI" model? (92CivicSiR)
Since when? An EX has no sunroof? No 5-speed?What are you talking about?
Old Aug 18, 2001 | 07:33 AM
Inaniac's Avatar
New User
Default Re: Did the 92-95 5th gen civic coupes come in an "SI" model? (CRX_VTEC)
the only things the hatchback has that the Ex coupe doesnt is rear disc brakes and stiffer spring rates.... everything else is the same.... and as far as the canadian one goes the EX was the Si yes.... thats why the new Si is called the SIR in canada...
Old Aug 18, 2001 | 08:16 AM
4doorRS5spd's Avatar
New User
Default Re: Did the 92-95 5th gen civic coupes come in an "SI" model? (Inaniac)
Your still all wrong. The only difference between the Si and the EX is a litle bit of weight and the body. The Si is shorter, but it's a hatch. I have a 94 Ex coupe, and I will be the first too tell you that I have factory rear disc brakes, as well as ABS. We, the Si and the EX, have the same sunroof, same controls, same stock gauges, same power windows, same evrything. Hell, even the size of the corner lenses is the same. The sedan (ferio) has different corners. Anyway, hope that clears things up. It's just a badge.
Old Aug 18, 2001 | 12:03 PM
ourkid's Avatar
New User
Default Re: Did the 92-95 5th gen civic coupes come in an "SI" model? (accord55)
Hey
I am from canada and have a 95 eg coupe. Mine has rear disk brakes. The only difference between the american(EX) and canadien(SI) is that the american version has power windows and locks whereas (canada) did not get them. Also, I believe the american EX has a rear wipper, and the cdn SI does not. Maybe there is a stiffer spring rate, but that does not compesate for the power locks and windows BOOOOOOOOOOO!!!
Oh ****, i forgot. NO ABS over here... Thank god, Who needs it! Pumping the breaks all the way!
accord55- No, we did not get power windows/locks. We did get power sunroof.
Take care
OuRKid
[Modified by ourkid, 4:05 PM 8/18/2001]
[Modified by ourkid, 9:09 PM 8/18/2001]
RTE117
Oct 14, 2014 11:04 AM
Gimme Wafflez
Oct 10, 2013 12:57 PM
GoLowDrew
45
Jun 21, 2013 11:48 AM
Jdmcivic98
May 27, 2004 11:30 AM
civicracer1993
Jan 29, 2003 11:12 AM
