best alpine amp to use?
Old Sep 1, 2003 | 03:53 PM
FatJoe's Avatar
Default best alpine amp to use?
i just bought an alpine type s 10" sub in a sealed enclosure that is 1 cubic feet. im not too sure if its a DVC or a SVC yet (either way i got a great deal so i decided to jump on it before time ran out on the auction). im wondering which alpine amp i should get to power it. i believe its a 600 total watt sun with 200 RMS. and its a 4 ohm SVC or dual 4 ohn DVC. i just want it to sound nice and clean. and i heard when ur using a sealed enclosure u need more power to run to it to get a good sound. so should i run 200 watts RMS to it or something like 300-400 watts RMS? thanks a lot!
Old Sep 1, 2003 | 07:28 PM
rjr162's Avatar
Default Re: best alpine amp to use? (H22Accord90DX)
any 2 channel alpine amp that is about the same RMS or a little higher than the sub would work fine. Type S's are SVC... but if you plan on possibly getting another sub down the road get a mono that's about that power RMS @ 4 ohms. This way you'll have the power to run both well
Old Sep 1, 2003 | 07:35 PM
bryan305's Avatar
Default Re: best alpine amp to use? (rjr162)
http://www.alpine-usa.com/html/D2_n_1_n_n.html
Old Sep 2, 2003 | 12:23 AM
FatJoe's Avatar
Default Re: best alpine amp to use? (bryan305)
actually there is a DVC type s...
SWS-1041D
10" Type-S Series Subwoofer (4ohm + 4ohm)
Target Retail Price US $120.00/CN $229.00
Key Features
• Frequency Response: 30Hz – 2kHz
<U>Dual Voice Coil Design</U>
• Kevlar Reinforced Pulp Cone
• High Excursion 3/4” Santoprene® Surround
• Dual Progressive Nomex® Spiders with Integrated Tinsel Leads with Edge Control
• Compound Radius Curve Pole Geometry
• Custom High Strength Basket
• Bumped Backplate
• Extended & Vented Pole
• High Strength Brass Voice Coil Bobbin
• Heavy Duty 8ga. Push Terminals
• Magnetically Optimized Motor Structure (Pat. Pend)
• Designed and Engineered in the USA
why not get a mono amp that puts out about 250 or so RMS? wouldnt that be the best option for a single sub. im not plannin on ever getting more than one sub.
Old Sep 2, 2003 | 04:20 AM
EVIL Hx Coupe's Avatar
JBL 300.1 amps can be found for pretty cheap... And they're but it'll only work if your sub is DVC because at 4ohm it only puts out 150rms...
2ohm 300rms
1ohm 300rms
Old Sep 2, 2003 | 06:18 AM
rjr162's Avatar
Wow, seriously? I never even noticed.. damn.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Accord90DX &raquo;</TD></TR><TR><TD CLASS="quote">actually there is a DVC type s...
SWS-1041D
Key Features
• <U>Dual Voice Coil Design</U>
• Bumped Backplate
why not get a mono amp that puts out about 250 or so RMS? wouldnt that be the best option for a single sub. im not plannin on ever getting more than one sub. </TD></TR></TABLE>
Old Sep 2, 2003 | 05:41 PM
FatJoe's Avatar
alrighty so i found out its a DVC...i think im gonna buy a JBL 300.1 and run it at 2 ohms... now with a dual 4 ohn voice coil it can run in either 8 or 2 ohms right? hopefully so cuz then i can run the 300.1 in 2 ohms at 300 watts RMS which is perfect.
Old Sep 3, 2003 | 12:48 AM
You can do:
8 ohms = Series
2 ohms = Prallel
2ohm = 300x1RMS and the amp will run perfectly stable... Look for the amp on EBAY they're really cheap...
Old Sep 3, 2003 | 05:57 AM
FatJoe's Avatar
Default Re: best alpine amp to use? (EVIL Hx Coupe)
im one step ahead of you my friend...already found a jbl 300.1 for like 126 bucks... gotta love ebay
Old Sep 3, 2003 | 03:56 PM
rjr162's Avatar
the JBL BP's are sweet too
Old Sep 3, 2003 | 04:13 PM
FatJoe's Avatar
thats what it is...bp300.1
Freezen
Audio / Security / Video
Feb 11, 2009 12:25 PM
MinimalXistance
12
May 3, 2006 10:28 AM
weak_tec
Jun 25, 2005 01:09 PM
teg88
11
Oct 17, 2003 01:28 PM
ShowSpeed
10
Dec 10, 2001 09:20 AM
